Sony Ericsson / Sony : Software, Firmware and Drivers : Peter's Acoustic Mod v2 - for K800/W880/S500 and all other zapf models
@pedroPS
"I will really whip your lammas' ass"
if you dont correct the links you provided.... JK
update the links bro! theyre all pointing to R8 K800 DRC off files
Posted: 2007-11-20 09:36:13
the XS++ zip files are pointing to the correct files(only DRC off).......
Posted: 2007-11-20 10:25:10
thats the prob rocky!
its DRC off... it will do good if the available link is DRC ON....
anyway... hope Peter is up and about any moment now...
weve been anticipating this update....
forgive me for being dumbo Peter!
theres a MIRROR link below Peter's post on the very first page..
sheeeshhh!
[ This Message was edited by: rockygali on 2007-11-20 09:44 ]
Posted: 2007-11-20 10:38:41
Did ne1 try out the new acoustics......? If so plz post ur reviews.....
Posted: 2007-11-20 11:49:40
Wat is DRC??? I alrdy try both, didnt see any differen
Posted: 2007-11-20 12:38:49
me too... i guess its up to peter to tell us whats going on...
Posted: 2007-11-20 13:19:16
Actually you're half right.
Original acoustics doesn't swap channel...but the HPM70 with swapped audio are original
And probably most of hpms are swapped...
I have noticed that there are some HPM70 that are not recognized as HPM70, and they are original too.
Dunno why, maybe the OEM ones are like this, and the ones that comes with the phones are good.
Can you listen to this mp3 and tell me if its swapped or not?
Virtualbarbershop.mp3
go to play time: 1:05 and listen
Oops. Sorry, I've tried fake HPM-70 once and it swapped my channels, so I guess it's due to non-original HPM-70.
In fact I'm not using HPM-70.
The one I'm using is iTouch SRC100 that came with W800i in Hong Kong.
I'm using original acoustics.
Yes, I heard the sound at my right hand side
Posted: 2007-11-20 15:00:50
Hi Pedrops, i'm using Phillips headphones and original w810 port to connect them to phone. and yes, the channels of your acoustics are positioned wrong because ive downloaded that mp3 and listened to it on the computer - the sound was to the right when he said "moving over to your right hand side". but with your acoustics its the other way round.
Maybe it's to do with HPM-70 headphones? Iv' lost mine so i cant test the sound on them, but if you can, can you please do something? thanks
Posted: 2007-11-20 18:08:15
Is there a way to install this to a Sony P1i
Posted: 2007-11-20 19:25:54
Hi all!
Sorry taking so long!
Links are fixed now!
About the HPM70 and swapped channels
please read this post at Se-nse: Page 14 / Post 266
Bugs on original HPM70
I don't have much time now, but tonight I'll answer everything with time ok?
Oh, about DRC on and off
I prefer DRC off, its more clear sound!
But DRC on will limit maximum power output and will NEVER crack!
you can read something about it here: Page 12 / Post number 226
Discussion about DRC on or off
The link were removed there, but the final packs are on page 1 of this thread
[ This Message was edited by: pedrops on 2007-11-20 19:06 ]
Posted: 2007-11-20 19:51:46
