Software, Firmware and Drivers
> K850 Firmware Overview
Hi, I got my new K850i from Netherlands BellCompany, so it is unbranded phone. Mine is 029 070922 version Velvet Blue, is there UK has Illuminated green unbranded version? And I read this post a lot, but there was no mentioned about...
WMA file play failed sometimes when I play MP3 file 2 or 3 hours, and try to open WMA file. It can be solved by restart phone.
Dusts are infiltrated inside of shutter cover glass, it is really supprise because this is new phone that I bought just 3 days ago...!
I tried to clean up but no luck, so I strongly tapped the glass cover couples of times and it disappered. But I'm worrying because it should happen again!
And another one, the touch softkey, is it works clearly at all times? Sometimes it doesn't respond. I think this isn't from hardware, it is probabely software malfunction.
There is no clock when sleep mode, but you can see clock by pressing volume key. It is annoying though.
[ This Message was edited by: MadRabbit on 2007-11-12 21:44 ]
Posted: 2007-11-12 22:42:08
Morning Everyone.
Has anyone else noticed a minor glitch with the SE software. When i recieve an SMS with my K850I connected the SE software disconnects from the phone.
So it becomes a bit of a pain to reply.
Posted: 2007-11-13 11:25:13
Has anyone noticed that when MicroSD Card inserted in memory card slot, everytime the phone is turning ON it requests to format the card?
This is not happened to M2 card anyway.
Posted: 2007-11-13 11:56:15
Yea, that happends on mine. It's currently sent away to have the flash & squeaky case fixed - hoping the firmware upgrade will also sort this out as have to be very careful what you touch when you turn it on!
[ This Message was edited by: Dart5 on 2007-11-13 13:09 ]
Posted: 2007-11-13 14:08:06
Just got my second K850i this morning. It is using the newer RICA037 firmware so hopefully won't experience as many problems. Fingers crossed!
Posted: 2007-11-13 15:52:51
I have a 2GB SanDisk microSD and haven't had this issue...
Posted: 2007-11-13 19:16:30
So do I and have no problems with it
Cheers
ENJOY
Posted: 2007-11-13 19:21:06
Hi AntonyS, Is your phone Illuminate Green and 037 firmware?
Could you plz tell me which brand is yours?
Posted: 2007-11-13 19:45:23
Good Evening,
Well this morning my phone was swapped over with the courier, but this is the only chance i have had to use the phone.
This is my third unit from o2 and I cant fault O2 in any way, they have been superb in swapping over my phone with out any hassle at all.
Any way, my previous 2 phones had R1CA029 on. My new O2 this morning has R1CA037. So if you get a new phone from O2 Direct from today onwards, the new phones are being shipped with R1CA037. (New Stock on Monday Morning at O2 Direct)
Some O2 shops may still have old stock though.
Any First impressions.
Camera does seem to be in sync with the Flash. I have took many Pics and the Flash seems to fire with the Camera.
Pics also seem brighter as well.
I havnt had much time to play with anything else.
But when i do I will post on here.
Let me know if you want me to try anything with the phone.
Posted: 2007-11-13 20:06:14
is the stand-by clock displayed?
Posted: 2007-11-13 20:11:39
