Sony Ericsson / Sony : Software, Firmware and Drivers : SE k800/k810 patches & ELF`s !! (update 21-04-2008)
On 2008-03-15 01:36:59, DeKosta wrote:
On 2008-03-15 01:11:40, the13thing wrote:
Can someone help me? I was trying to patch my K800i but:
[ This Message was edited by: the13thing on 2008-03-15 00:13 ]
You have CID49. You should flash your K800 to the latest firmware.
And for the second, have you applied the quick access patch?
And for the third, correct the img link, remove the "url=" and just paste the image link.
And for the forth, why does it look like you have choosen a K610 file when you have K800?
And did you press "ready"? If you want to patch you have to press "write script" and then answer the popup.
"YES for uninstalling a previous installed patch and NO for installing the patch."
[ This Message was edited by: DeKosta on 2008-03-15 00:43 ]
I have a unlocked but branded phone and i can't update it using SEUS...And i don't know how to do the update using SEtools...
No i don't have applied the quick acess patch
Im going to correct that now
I choose K800i
I can't press ready because it apears an error in the list...
The popup doesn't appears...
I'm following this tutorial:
http://www.plusgsm.com.br/forums/showthread.php?t=42029[ This Message was edited by: the13thing on 2008-03-15 01:25 ]
Posted: 2008-03-15 02:22:58
Hi, i m requesting to all of you for key lock password patch or password on menus patch for K790i - R1KG001, CID52,
i really need for this patch. i've searched your site
http://theshadow03.4shared.com but no success.
plz make it for me.
My Phone model is : K790i
My Firmware is: R1KG001
CID: 52
i m waiting for your reply
thanx
Posted: 2008-03-15 06:46:19
for k810 R8BA024
ego's bee battery icon edit to blue by me
http://www.4shared.com/file/4[....]e.html?dirPwdVerified=9aa120a5
Gerold's mix battery icons
black and blue
black and red
http://www.4shared.com/file/4[....]d.html?dirPwdVerified=9aa120a5
Gerold's Volumebar
http://www.4shared.com/file/4[....]r.html?dirPwdVerified=9aa120a5
Gerold's Theme icons
Smiley theme Icon
http://www.4shared.com/file/4[....]n.html?dirPwdVerified=9aa120a5
Theme icon to Animated photoshop icon(
[ This Message was edited by: geroldbravo on 2008-03-24 07:17 ]
Posted: 2008-03-24 08:10:17
to all
i`ve changed the name of my 4shared account....had some problem`s with it...the new adress is this:
http://theshadow86.4shared.com
SE k800i --> K810i (R8BA024 MAIN & R1KG001 FS), CUSTOM made MENU and ICONS, ModMix v1.5 MF cam driver, Peter`s v2 for R8 (Monster Bass DRC On + Mid_Extreme v3.1 farfield play & ring),Simpsons fixed font + Carbon Finale, vkp PATCHES, WMP_11 Player PATCH
[ This Message was edited by: theshadow03 on 2008-03-24 12:23 ]
Posted: 2008-03-24 13:22:55
Thank you theshadow03 ! I was successful in patching my k810i thanks to your guide.
The only problem I had was that in SEtoolLite when i clicked "Read GDFS" i had to remove the cable & hold C & reconnect the cable.. This happened most of the time like when i needed to flash the phone, add multiple VKP scripts, I always had to remove cable, Hold C and reconnect cable. But anyway it works
Thank you again !
Posted: 2008-03-25 07:46:16
On 2008-02-12 12:09:58, geroldbravo wrote:
@dekosta
try to request for the patch "full access to filesystem thru java program"
it's easier, you dont have to plug in your phone to pc and you can see all the filesystem in a java program like moby explorer or minicommander...
but i suggest moby, it's a lot easier... just put camdrivers, acoustic drivers, menu icons etc.. to the folder "other" and then if you want to change camdrivers or anything you want you just delete the file that you want to change and paste the one you want to use..
Hello geroldbravo,
Im new w/ patching and would like to know that if i use "full access to filesystem thru java program" patch & moby , would that mean i would not need to use the "move camera & acoustic to other.vkp" anymore? since i can access the file system already? ifs/settings/....etc..
thank you
Posted: 2008-03-25 10:02:10
plz make it for me if anyone can.
CID: 52
thanx
Posted: 2008-03-25 13:05:11
@dekosta
Hello geroldbravo,
thank you
yes it is.. you don't need to that because as what you have said, you have the access to filesystem with a java program like moby or minicommander, but i suggest moby... (font's,menu icons,cam drivers,acoustics,disp driver etc.. can be seen thru your phone) anyway, you just have to restart your phone if you change fonts or menu icons because you can't see what you've uploaded until you restart/reboot your phone...
Posted: 2008-03-25 16:05:59
I update my K800 whit SEUS and after that it show me the message "Insert correct SIM card" so that means it's locked. New firmware is R8BF003 , EROM CID:53 and OTP CID:51. How can unlock it cause Setool 2 Lite or SX++ doesn't work. Or maybe I don't know how to use it. Please somebody can help me? theshadow03 vrei sa ma ajuti te rog?
Posted: 2008-03-25 20:53:42
Wow, okey i just read a thread that is stating that SEUS updates K800/K810(+ some other models) phones to CID53 and this CID is not moddable as far as i know just JDflash has some sort of support for it.
And you cannot downgrade CID...
So folks dont use SEUS to update the phone.
I am sorry mate i dont know why it says that about your simcard..
[ This Message was edited by: DeKosta on 2008-03-26 19:53 ]
Posted: 2008-03-26 01:23:11
