General
> Official C510 discussion
thanx chancooluk
Posted: 2009-04-23 19:40:52
Ah hello there sorry was bit late coming on. Glad you got the firmware updated. Most of the c510s in the shops now seem to have the R1DA032 firmware which has the split screen problem and sometimes the odd screen flicker but this is resolved by just turning phone off then back on and it stops only happens once in a while. I found the split screen happens when sometimes i change from 3G back to GSM. Now where did you buy your phone from cos even though its fine now if it was a week old where you got it from should just replace it with new. Most places offer 28 days if faulty after which time its repair. But glad ya sorted it with SEUS. So far with this firmware there are no major bugs
Sorry was bit late on i been at work. Will help where i can.
Posted: 2009-04-23 20:03:00
but again a new problem occured whenever i remove the battery and put it back in Its shows 0%
Now i understood this all is happening due to so many messages i send to my friends
SO PLEASE avoid SENDING SMS guys
THESE bugs are all due to messages
I think i should replace it now
Posted: 2009-04-24 07:22:08
ok its working fine again i reflashed it again using seus and now its back to normal but i noticed something when the mobile had again got spoiled the internet speed was working superb fast than before and now its again back to normal
Posted: 2009-04-24 08:18:58
You should take your phone back to where you got it from get it exchanged. Your problems dont sound like anything i have had. Mine never has battery problems then having to flash it never crashed or restarted once maybe i am just lucky but so far not many people on here have complained about the phone. Yours could be just bad batch but like you said it had older firmware. Mine has same firmware as yours but i dont have any problems whatsoever. Except the mirrored split screen thing sometimes. I also send lots of messages but my battery is fine i only find battery drains quickest on internet usage but that happens on most phones. I suggest you return it when you get new one flash to new firmware again if it aint got it then see how it goes from there. Also sounds like your hammering your phone lol. But thats a dud i think with the battery going like it is its not normal for a new phone to go that bad. If your using the phone alot during the day with 3G on the battery will go fairly quick turn off 3G.
[ This Message was edited by: Bonovox on 2009-04-24 12:50 ]
Posted: 2009-04-24 13:35:00
Does anyone find the reception signal quite poor on their c510? I live in high quality signal area on Orange and all other networks except 3UK and on this phone the signal is poor at times. Fluctuates way too much on GSM or 3G. Wonder if it can be improved with new firmware? Anyway i am off to visit family in Ireland for one week now so cant talk on here for while.
[ This Message was edited by: Bonovox on 2009-04-25 02:35 ]
Posted: 2009-04-25 03:25:00
im considering a c510 or a k800i can anyone compare the cameras i just cant make my mind up where to invest my money
ive got a k750i at the moment an id like a better camera for the few pics i take im not fussed about led or xenon flashs as its daylight pictures i shoot
theirs someaspects of a200 i like the application shortcuts auto roate but im not so keen on the search button or media on the home screen
any advice would be useful
[ This Message was edited by: daydotz on 2009-04-27 12:20 ]
Posted: 2009-04-26 11:49:13
Is there a way to increase the sound quality of C510..
I bought it today and am not satisfied with the sound
Posted: 2009-04-28 19:04:54
AMAZING C510 OFFER
500 minutes & 100 texts, a FREE phone all for just £10 a month!!!!
http://shop.vodafone.co.uk/sh[....]t_paymonthly&_requestid=444230
You might be put off because its a 24month contract, but once youve done with your c510 you can sell it and put you voda sim in your new phone, and sisnce most top up £10 a month its really an amzing offer
Posted: 2009-04-28 22:00:42
daydotz
don't look only at the camera. even if K800/K810 is somehow better it's not that much important. C510 is a new phone in good size with good features and the camera. maybe more expensive but not much I guess
Posted: 2009-04-28 22:48:17
