Regional >
Americas
> Programas necesarios para tu Nokia serie N
Ya es de tarde, lol.
Posted: 2010-02-26 23:15:22
Gravity con soporte para:
-Twitter
-Facebook
-Laconia
y ahora four square.
Aqui es
ta el beta:
http://www.4shared.com/get/222450479/4d4cd51b/MobilewaysGravityv1306325S60v3.html
Posted: 2010-03-07 21:44:26
Nokia C6 Leaked!
Posted: 2010-03-12 22:08:15
Pa los que instalan el Zensis Photorite SP que esta en Opda, usen esta fecha pa la instalacion:
03/18/2007
Asi no les sale expired certificate.
Posted: 2010-03-18 16:16:28
KickYouTube.com is the easiest way of downloading YouTube videos.
Just put kick before youtube on the video url. So for example, if you have the following url:
http://www.youtube.com/watch?v=R7yfISlGLNU
It would look like this:
http://www.kickyoutube.com/watch?v=R7yfISlGLNU
And then you will be able to download the video in a variety of formats, which include MP3 for audio only.
As an alternative, you can use our handy bookmark, located at the upper right corner of this page. Just drag the star icon into your bookmarks toolbar and you’re all set.
Be sure to watch the video on the front page for a more detailed view of the process.
Posted: 2010-03-23 19:47:03
3outube.com is another web-solution to download YouTube videos in MP4 or Flash formats ONLY, for the moment.
Note that :
“… we’re still having intermittent troubles on some videos. We are working around the clock to have this problem resolved. We are also in the process of adding more formats, e.g. MP3, 3GP, HD… etc. and compatibility issues with Chrome and Safari at the moment.”
Similar process as in kickyoutube.
If you have the following url:
http://www.3outube.com/watch?v=R7yfISlGLNU
Enjoy!!
Posted: 2010-03-23 19:54:46
Como diría un mexicano cualquiera: Gracias mano!
Posted: 2010-03-24 12:54:51
Strong, bajate el BeyoCBS pa q tu veas lo q se llama innovation!!
http://m.beyocbs.com
Ese programita sirve pa lo sgte:
Le tomas una foto a un periodico, revista, etc, y el tiene un software OCR cheverisimo y luego te comienza a leer a lo q le hayas tomado al foto!
Posted: 2010-03-24 16:09:12
Nítido ahora mismo lo descargo. Espero que lea en castellano lol.
Posted: 2010-03-24 16:26:13
Aparentemente todas las páginas que daban servicio de descarga de videos de youtube incluso el reproductor RealPlayer tomaban los recursos de una misma fuente ya que ninguno puede descargar videos de Youtube. Por otro lado el BeyoCBS está nítido sólo que lee en francés aparentemente.
Posted: 2010-03-25 15:21:47
