Sony Ericsson / Sony : Software, Firmware and Drivers : (vFinal_rev5) AudioPhile Premium HD Acoustics for All A2 & UIQ3 Phones
@Hiron,a suggestion.
Make 2 versions of .csv files,one for non-clear bass and that present in your pack.
Cheers!
Posted: 2009-12-11 22:05:10
Hi there again, here is my UIQ3 tutorial for the sound mod!
AudioPhile Premium HD Acoustics for -UIQ3- Phones
Programs needed on the phone:
- CapsSwitch AND
- Swiss Manager (goggle them, download them, install on the phone) AND
- se_sound_patcher_full (google again, and download on the computer)
Now let’s do the work:
1) Unlock access to system folders (use CapsSwitch - capabilites off)
2) Copy file "mmmgmtserver.exe" from 'Z:\\sys\\bin' (ROM drive) to 'C:\\sys\\bin\\' (use SwissMgr, show system folders)
3) Copy the file 'Z:\\sys\\bin\\M3SAudioPolicyMgr.dll' from your phone to computer
4) Run se_sound_patcher_full, select the file 'M3SAudioPolicyMgr.dll' copied from the phone and press "Install"
5) Copy the patched file 'M3SAudioPolicyMgr.dll' back to your phone to the dir 'C:\\sys\\bin\\’
6) Copy all the contents of 'Z:\\private\\10200B19\\AATFiles' to ‘C:\\private\\10200B19\\AATFiles’
7) Now take the downloaded Audiophile premium HD acoustics... We need the folder 'wbxml to ifs-settings-acoustic'. Change all the files’ extension to '.aat' !
(We do NOT need the following files: ‘line_out.aat’, and ‘PHF_4_play.aat’)
8 ) Move them to the directory 'C:\\private\\10200B19\\AATFiles\\' and confirm replace!
9) Restart your phone.
10) Enjoy.
Re- and uninstall:
Do delete the files you need to use the ‘cut and paste’ method using Swiss Manager, deletion will not work! Just cut the newly created AATFiles folder and paste it to an arbitrary non system folder (for example put it simply on D:\\) . From that place you will be able to delete the files, as they no longer will be in use. Do the same with the patched .dll file and the .exe file as well.
To reinstall the files, or update to a newer version, use the same method as above, except not with the whole folder, but just with the Audiophile .aat files. You do not need to restart the phone!
Greetings
Falconer
Posted: 2009-12-11 23:07:34
@Rajneesh17,
try to restart your phone and use a different cable and headphone...
If the sound is not balanced it is likely that there is a problem in a fastport connection (could be loose etc)... I have experience it once and played a bit with a fastport
@FalconerHUN,
Thanks for the tutorial! Will add it in the readme in the next version...
@loveynn,
Err... I don't really know about Altec in terms of headphones, really
@luhccas-c905,
Here is some things that I know. Correct me if I wrong:
1. ClearAudio phones parse vol_cb_on*.csv and vol_eq_off.csv. vol_emp_eq_on.csv doesn't affect them.
2. Standard MegaBass phones parse vol_emp_eq_on.csv and vol_eq_off.csv. vol_cb_on*.csv doesn't affect them.
3. I copied ClearBass value from vol_cb_on*.csv to vol_emp_eq_on.csv and the bass in Standard MegaBass phones becomes much better now
So based on this, I thought we doesn't need to separate it anymore?
Hiron
Posted: 2009-12-12 01:29:31
Er..i listen to every music xD
Anyways i got an ipod touch. The sound quality is quite disappointing.
Is there anyway to make it better like modding it? xD
Posted: 2009-12-12 02:20:02
@Hiron let me explain what i mean
i'll take one line to use as example:
0;-14;14;1989;0;6B231A90;7FFF67D3;0;0;4;07FF;0;
X;4D;4D;4D;4D;7F;4D;4D;4D
The "X" with 0 value will not be recognized as it should be.
The rest of the line is for volume steps(in megabass phones only).
But this just will work if the "X" are 1,understand?
Turning off that steps the phone will just recognize the dB gain (in this case 14,in the third column).
Unfortunately this works like that
Thanks and excellent work,like always!.
Posted: 2009-12-12 03:39:33
great!
Posted: 2009-12-12 04:38:55
I've tried v6.1 Crystalizer Booster..this realy great acoustic driver...
Posted: 2009-12-12 17:27:47
Is this mod anything like SoundModLite for UIQ3? If yes, I can´t wait to install it on Satio. A step by step howto would be nice to place here.
Posted: 2009-12-12 18:58:06
hi hiron
i've uploaded the necessary .csv and .wbxml (amplified) version into my W995 and tested it using my ancient mdr-023
, hpm-70, hpm-78 and mh-100, woww the volume is louder, sound is cleaner and clearer no hissing and the bass/treble output is well noticeable (using preset setting). overall the vx2 is a superb acoustic driver and its better than the stock driver...
argh it's time to get one of those good Hi-Fi Audiophile Headphones
Posted: 2009-12-15 21:23:15
this is really great driver
Posted: 2009-12-16 09:28:47
