Sony Ericsson / Sony : Android : Xperia ray Official Thread
< Esato Forum Index > Sony Ericsson / Sony > Android > Xperia ray Official Thread Bookmark topic
Page <  123 ... 373839 ... 888990>
Zzzyzx Posts: 76
Hi jplacson, just to be sure if the Ray indeed supports the ambient light sensor and it's working fine, can you also check the Service Menu of the phone *#*#7378423#*#*
You can test diffferent features/parts of the phone such as screen display, sound etc.
If Ray supports ambient light sensor, it should show up in that menu. You can test if it's working by checking if the value of the ambient light changes.
Posted: 2011-09-26 05:37:44
HxH Posts: > 500
hope this help!
Posted: 2011-09-26 05:42:01
jplacson Posts: > 500
@Hxh, Thanks, I see where it is now. It's quite tough to spot without shining a flashlight close to the phone surface.
Posted: 2011-09-26 06:06:39
Zzzyzx Posts: 76
^^^ so does it really affect the brightness of the screen when you go to a low lighted room?
In my Xperia Mini, the adjustment of the screen brightness is very noticeable if you go from one place with ample light to a dimly lit room. I am really planning on switching to Ray if the case is not as bad as in the Mini.
Posted: 2011-09-26 07:13:04
massimax Posts: 27
AGAIN??? We already said that it DOES NOT affect the screen brightness AT ALL. You set it manually and it remains the same out in the sun or inside a dark room. I don't know why the sensor is here if it doesn't work as it should but that's it: it DOES NOT dim the screen in low light conditions nor it brightens it up when outside
Posted: 2011-09-26 12:57:48
Zzzyzx Posts: 76
^^^ Sorry. I just wanna be 100% sure that it doesn't affect the screen brightness ;p
Posted: 2011-09-26 14:46:33
Try putting your finger over it
Posted: 2011-09-26 15:12:32
wiraperkasa Posts: 295
http://www.soyacincau.com/2011/09/26/xperia-ray-a-design-story/
Posted: 2011-09-26 16:56:22
xperia ray unboxing teaser video
Posted: 2011-09-26 17:27:19
nevinp007 Posts: 17
Xperia ray's price in india is 21600 rupees. (389 american dollars)
Posted: 2011-09-27 12:26:20
