Android
> Xperia P discussion thread
Am quite surprised on the battery life. Been using this all day on & off & I still got 72% left
Not extreme heavy usage but kinda average usage. Considering it has a 4" qHD display with dual core & a 1,300mAh battery it is surprisingly efficient. The side speaker has great crisp clarity I really like it. I do keep it on auto brightness with white magic. That display though is so so bright it blinds me
Posted: 2012-11-28 18:37:54
Good stuff, my one is still going strong. I've ditched my E series Walkman for this because I seem to get much more bass on my phone with the Walkman player. The screen is way too bright for me so I keep it at 50% always.
I'm using Blink app to change the LED notification light but its glitchy unless I have Illumination Bar app running with it. Strange but it happens with all LED notification apps for me at least.
As much as I like the Xperia T and others, I love the transparent strip too much. The phone looks way better than anything else. Happy days.
Posted: 2012-11-29 12:33:48
the screen is disturbing me... yellow colors look like green... the color of the battery in the notification bar is olive green...
what is the latest fw version? PC companion tells that there's a fw update for my phone... but it's the same fw version
i'll try to update it later... hope that it will solve my problem...
edit...
I set the quick launch setting of the camera to launch and capture but when I slide the camera in the lockscreen it only opens the camera app instead of opening and then capturing...
[ This Message was edited by: juris15 on 2012-11-29 12:16 ]
Posted: 2012-11-29 13:02:56
You may have misunderstood the function. It is supposed to work with the camera button, not the slide on the lock screen. With the screen turned off, just press and hold down the camera button for a few seconds and it will take a picture.
[ This Message was edited by: Arne Anka on 2012-11-29 13:17 ]
Posted: 2012-11-29 14:17:05
I'm a heavy user so it lasts me less than a day. But on light use, my battery drops 1% per hour.
Yes, the screen is quite bright, even on the power save mode. Sony could've actually added a lower auto-mode about 30% dimmer and it would still be ok.
Posted: 2012-11-29 14:24:54
what settings did you have on the camera when you took the nighttime pictures?
Posted: 2012-11-29 14:52:35
edit...
On brightest setting mine does not look green. Done some shots today
Posted: 2012-11-29 20:17:21
edit...
You may have a bad unit. At worst, the White Magic screen adds a slight yellowish hue, not green... and certainly not THAT much green.
The quick launch works only during screen lock, if you unlock the screen, it disables quick launch and just launches the camera app in normal mode
Posted: 2012-11-30 02:53:52
maybe I was just exaggerated about that color green
it isnt really green, it's more of dark yellow... I'll try to post pictures later...
There's a new FW update 6.1.1.B.1.54, and I'm updating
@Arne Anka
thanks for the clarification
@Bonovox
Beautiful shots
[ This Message was edited by: juris15 on 2012-11-30 02:40 ]
Posted: 2012-11-30 03:24:54
I don't notice any screen colours being odd. I did on the Samsung Super AMOLED screens with a blue ish tint to whites. Sony screens always look so sharp. I swear cos of the pentile display in the GS3 my Xperia P display looks sharper even though it's less pixels. As for my shots,thanks
Posted: 2012-11-30 04:01:00
