Sony Ericsson / Sony : Software, Firmware and Drivers : fMA f[??] Mobile Agent, software for sms and phone monitoring
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > fMA f[??] Mobile Agent, software for sms and phone monitoring Bookmark topic
Page <  123 ... 373839 ... 106107108>
T68i user Posts: 16
Sorry but what do i put in options/script as a scriptfile?And then do i choose to edit script and the options?And what if i want to put more than one script?
Posted: 2002-12-25 17:06:00
GOwin Posts: > 500
download a sample script, open it and see how it works
Posted: 2002-12-26 02:20:00
neotace Posts: 16
everytime i try to start fma it fails and says: "Error 10047 in function Connect (socket) Adress family not supported by protocol family"
how can i solve the problem??
win xp pro, msi bt stick (tdk 1.2.2.18)
thanks
Posted: 2002-12-26 17:02:00
chungagoring Posts: > 500
i'm afraid my p800 doesn't work in mobile agent. it works fine with the rest of the software and mpm is running but float's says "connection error" just a few seconds after starting it. the thing is that under tools, the connection options are only bluetooth, irda and serial cable, but what about usb cable? i mean, p800's craddle.
Posted: 2003-01-10 16:29:00
float Posts: 173
I notice the problem with P800.
1. I can't connect via Bluetooth, my driver disconnect immediately after connect, i suspect this has got to do with the Bluetooth Driver.
2. I can't connect via IR, error message shows something like "9wire", i suspect FMA needs a better IR implementation
3. I can't connect via USB Cable (it's serial, just select the port created by the USB driver), but since my port is COM16 or something and FMA can't use COM port above 10, i can't connect too
Thus i have no idea if FMA works with P800 at all, other than the communication layer problem. (again: no promise when to solve, too busy currently)
p/s: Watchout! FMA is soon to go Open Source, so DIY
/floAt
Posted: 2003-01-12 14:52:00
GOwin Posts: > 500
congrats on your decision to go Open-Source!
Posted: 2003-01-12 15:39:00
619 Posts: > 500
too bad fma cant be used w/ P800 yet. well, im still using my t68.
Posted: 2003-01-14 18:03:00
hamslay Posts: 3
Hey float
I am so close to getting my Bluetake BT USB dongle and T68i working. I already got Outlook synchronising and the last thing was to send some pictures to the phone. The Bluetake website recommends your software, which I've got running, but my phone is using port 13. Your Serial Port stuff in the Options dialog only allows the serial port to go up to 9! Is there anything I can do?
Thanks!!
Posted: 2003-01-15 14:33:00
GOwin Posts: > 500
@hamslay
just change the com port that your phone uses to a port that fma can use.
Posted: 2003-01-15 16:07:00
hamslay Posts: 3
GOWin, that did cross my mind, but I can't select a lower port. If I go into the Bluetooth Configuration dialog box and select the Bluetooth Serial Port, I can only chose between COM 13, 18, 19, 20, 21, 22 and 23. It seems Windows has already allocated the lower ports.
I had a look at which port my old 56k modem is using and it's on COM 12, with all the lower ones showing as "In use". I don't know whether this has something to do with my motherboard having 6 USB ports or something, but I just can't find out what's using COM 1 through to 11
[ This Message was edited by: hamslay on 2003-01-15 17:50 ]
Posted: 2003-01-15 17:50:00
