Sony Ericsson / Sony : Themes, ringtones, screensavers, games, video clips : Vinnie's Themes- added The Square Effect K700 Theme-for the T610 and K700
Thanks
, and glad you like it
, i have seen an animated ferrari screensaver somewhere at esato.
@Jowi, i learnt how to do it with MO's tutorial:
http://members.lycos.co.uk/mosedrengen/tutorial/ with the template, i got the T68i template from TCP in the templates directory.
for the instructions on the highlight in mo's tutorial, search for this:
Save this T610-desktop-image
and it's from there
Posted: 2004-04-14 21:18:32
@vin-i cant find the template. did you rcv my email? can you convert the pics? (just convert not make a theme) ? thanks so much
Posted: 2004-04-15 10:21:29
@vin-ok, i made a template from the ferrari pics above...i made it all white just what i saw in the tutorial. But the problem is, i can't convert it the way you convert it. ah...damn...
Can you just convert the pics i sent to you? thanks man!!! you're the best!
Posted: 2004-04-15 12:23:03
my dear vinn...hmmm what can i say
you and vlamm have kicked your themes into high gear!! great stuff keep it up bro
Posted: 2004-04-16 07:43:12
@vin-ive d/l the pics from your site, thanks
Posted: 2004-04-16 11:11:38
OK, hope they're ok Jowi
thanks scub, here's another experiment, my cold space K700 theme:
Hope you all like it and comments plase, as you can see i'm experimenting wwith photoshop, this theme tells a story, there was a spaceship in space, then the door and window started cracking, then it broke off and froze up
Posted: 2004-04-16 18:37:49
Yeah! Nice job vin. I But I promise you that if you had spent another thirty minutes with that program it would have been even better. It always gets with that program... What version do you have?
Posted: 2004-04-16 19:28:13
i have PS7, the problem is i'm not that good with photoshop (only a beginner), i need to read more tutorials and play around with it more to see all the things i can do
Posted: 2004-04-16 20:40:04
Same case with me... But you can make some great results from nor knowing what you're doing
Posted: 2004-04-16 20:52:47
I think its lovely Vinny lad
Posted: 2004-04-17 03:44:00
