Sony Ericsson / Sony : General : k700i De-Branding now possible with T28 service cable )
General
im trying them both together as i type. hope it works.
Posted: 2004-10-13 20:13:16
Just tried to do mine, both together, got:
Enabling functionalities....
Error connecting to server.
Phone dead, still got my credit though. Trying again.
Was using 1.30.
Posted: 2004-10-13 20:15:41
don't type while you flash your phone
No I really recommend that you don't do anything else with your computer while you flash the phone...
Which operating system you are using?
Velimir
Posted: 2004-10-13 20:16:13
@vee
if that was for me, im using XP SP2.
morak
Posted: 2004-10-13 20:18:03
@ morak
that was the scariest part for me also... It stood there for some time, but went through luckily... Maybe problem on the serverside...
Take care
Velimir
Posted: 2004-10-13 20:20:55
Joy!!!! Second times a charm!
Happy!!
(Working now)
Posted: 2004-10-13 20:24:43
about operating system...
someone suggested to someone to use WIN XP SP2 for the most convinient use... Don't ask me why or if it is true, but that's what I heard.
@ morak
After Enabling funcionalities... I got message: "There is 1 user connected to server..." whatever that means. Maybe your phone just couldn't connect at that time...
Are you trying again?
Velimir
Posted: 2004-10-13 20:25:41
yesssssssssssssssssssssssssssss. It worked. Now i need to get my credit refunded
Posted: 2004-10-13 20:44:01
about to debrand, can anyone tell me whats the difference between the language file (k7L) and the default language file (k7D)? are these both needed to get rid of the branding??
can the folks who've debranded using 1.30 post a 'simple' step by step guide. it seems to be quite different from the earlier versions.
cheers
Posted: 2004-10-13 21:20:55
@ suavay
for unbranding
click on repair/unbranding
select K700_R2AA003_ZONE_x.K7S
select K700_R2AA003_x.K7D
then flash
x - check
www.totalsever.net for language and firmware file you need
for unbranding you use firmware (K7S) and default language (K7D) files - you loose all the user data
for upgrading/language change - you use firmware (K7S), language (K7L) and customization (K7C) - you keep all user data.
ALL THE INSTRUCTIONS are now simple and clear in the program's help!!! Please follow them!
Velimir
Posted: 2004-10-13 21:26:43
