Sony Ericsson / Sony : Symbian phones : O2 PAYG free GPRS - works for me on p900!
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > O2 PAYG free GPRS - works for me on p900! Bookmark topic
Page <  123 ... 373839 ... 444546>
dekesh Posts: > 500
if there blocking your SIMs some of you guys must be using it 24/7. wow thats some mega usage but its all good
[ This Message was edited by: dekesh on 2005-04-05 21:46 ]
Posted: 2005-04-05 22:45:48
Si_V80 Posts: 453
No, i used 1mb ish and it just started charging...shit thing
Posted: 2005-04-06 13:41:32
dekesh Posts: > 500
Thats a bit wierd because i used about 7MB in a day and its still free. but that was a little while back so they might have realised it.
Another thing I recently rang o2 and asked them for the GPRS settings for a nokia 6230 and they said I have to enter them manually and so they e-mailed me the settings. And they provided the port 8080, which is a bit wierd because if its charging then it should be port 9201 as we have experienced. Make you think whether we are really using a loop-hole since o2 themselves are giving the port 8080. what do you guys think?
Posted: 2005-04-06 14:13:34
ten18 Posts: > 500
Still free for me dekesh. I used about 5MB today. not sure why hes getting charged after 1mb?
hah, o2 gave you port 8080...weird? they probably got the settings from the first page of this thread.
Posted: 2005-04-06 14:30:00
dekesh Posts: > 500
Posted: 2005-04-06 14:41:39
babysmile Posts: 263
Oh gosh.. THat's funny..
I'm just start to use it and can msn using the e messenger mobile version.
Pretty cool, but hard to type fast as in PC.. hahaha
Posted: 2005-04-06 18:17:38
nickorooster Posts: > 500
Wow! You can use msn!!! I'll have to give that a go!
Posted: 2005-04-06 19:16:15
nessaizfit Posts: 165
Can msn be used wen using the free gprs then? If so, share it with us lol
Posted: 2005-04-07 20:03:24
Yes it can! I tried using e-messenger mobile, at:
http://mob.e-messenger.net
and it worked fine! But I can't say its all that great, I only used it for a while, and I reckon you're better off not bothering. It works tho, so if you've a really important convo you have to get to, go for it.
Nick
Posted: 2005-04-07 20:13:53
If it aint all that gd then i wont bother, if it was a decent version of it then i would of, im mostly on the net anyway so i wouldnt need to use it on me phone desperatly. Thanks anyway for letting me know.
Posted: 2005-04-07 20:21:59
