Regional : Asia Pacific : INDONESIA corner
< Esato Forum Index > Regional > Asia Pacific > INDONESIA corner Bookmark topic
Page <  123 ... 373839 ... 131713181319>
twidi Posts: 0
ada yang mau sw camcorder utk P800? kirim email ke gw tutukwidi@yahoo.com
versi software hrs R2F, gw baru update dr R1B di SE Roxy mas lt dasar
Posted: 2003-08-08 16:32:59
wallpepper Posts: 25
Sending email using T68i with IM3-card
You'd have to get an account. I recommend from http://mail.softhome.net
It's one of the easiest POP3-based email account.
Onced you've logged in, you'd be easily send pictures as attachments (up to 5 each email) or merely writings.
Hope that'll helps!
Enjoy
Posted: 2003-08-09 07:13:50
T0nny Posts: 16
@t610s_d_best, kalo mau tau ada yg pake bt, connectivity -> bluetooth -> my device ->new device, kalo ada yg pake bt pasti kelihatan di layr. ada yg pernah coba kirim note ke nokia via bt? kalau bisa diterima, apa sebagai note juga ( bisa dibaca )? This message was posted from a WAP device
Posted: 2003-08-09 07:44:42
macica Posts: 7
Halo semua,
Aku penggunan T68i, baru beberapa hari jadi member esato, kalau download udah sering.
Oh ya ada yang mau aku tanya :
1. Untuk settingan email, aku harus masukin dns numbernya bukan servernya ( contoh aku pakai yahoo.com.sg jadi waktu masukin incoming servernya bukan pop.mail.yahoo.com.sg tapi angka-angkanyabegitu juga outgoing servernya) apa ini untuk firmware yang lama ?, aku masih R2E
2. Kalau mau upgrade bayar berapa ?
3. Kalau ada yang tahu dns number untuk incoming & outgoing server nya hotpop, tolong kasih tahu.
terima kasih
Posted: 2003-08-29 18:34:37
macica Posts: 7
Sepiiiiiiiiiiiiiii, haloooooo!!! This message was posted from a T68i
Posted: 2003-10-21 16:28:35
Halo, Macica! Met' dateng di Esato!
T68i nggak perlu ribet2 bikin email client. Pake POP3 aja. Praktis, cepet, bisa upload/download file attachments 5 foto sekaligus dll.
Lengkapnya bisa kamu baca di Majalah Cell4Teen edisi ke-2/terbaru tgl 20-Okt ini. Aku nulis di situ & udah nge'bahas soal POP3-Mail. Bisa buat T68i/T300/T310/T610
You've picked up the right technology when it comes to SonyEricssson. All you've got to do is have fun with
Masih mau nanya2 lagi? More questions? I'd be glad to answer.
By the way, I don't think most Indonesians have been quite familiar with the latest technology. Perhaps that's the main reason they wouldn't even bother to post any topics in this awesome forum
Enjoy your T68i It's a great phone!
Posted: 2003-10-22 05:49:32
kucibubu Posts: 93
hi guys...can i know the retail price for T68i in jakarta now???please..i realyy need ur help..thanks in advance.....
Posted: 2003-10-22 20:06:35
Chester_T610 Posts: 4
On 2003-07-27 12:09:13, T610s_d_best wrote:
halo semuanya, gue udah tau esato lumayan lama, tapi gue baru tau ada indonesia corner nya hehehehe
gue pemakai t610 neh, di Indo khususnya Jakartanya banyak gak ya yang pake T610
Gue ada beberapa pertanyaan neh buat pemakai T610 ....
1. Ada yang pernah ngalamin kalo HP nya tiba tiba blackout, maksudnya gak ada lampu, tapi handphone masih aktif, jadi kita gak bisa liat apa apa di layar, tapi kalo dicolokin handsfree lampunya nyala lagi... gue pake hp ini udah kira kira 2 bulan dan kejadian ini baru akhir akhir ini.. kira kira ada 2 - 3 kali deh ..
2. trus pertanyaan kedua, SW gue RIA081, ada yang udah upgrade SW nya menjadi yang terbaru, kalo gak salah R1L00013 ? apa ada efeknya gak ya ?
3. Pertanyaan ketiga tentang bluejacking, caranya tuh gimana seh ? apa untuk mengetahui orang yang pake bluetooth harus dengan cara send picture atau send polyphonic ke orang lain ? yang seneng kenalan lewat bluejacking coba deh di cheetos Jakarta, rata-rata yang ke sono anak muda yang udah pake bluetooth hehehehhe
ok deh sekian pertanyaan gue, tolong dibantu ya guys
ps : ada yang mau kenalan bisa kirim email ke gue antigious@hotmail.com
cya
Gua pemakai T610 di Jakarta juga nih.
Gua coba jawab pertanyaan-pertanyaan elo ya...
1. Gua belum pernah ngalamin problem kaya yang elo alamin itu, mudah-mudahan nggak deh. Tapi pernah sih beberapa kali nge-hang. Biasanya kalau gua akses GPRS pas sinyalnya lagi lemah banget.
2. Gua udah 5 bulan pake T610. Waktu gua beli dulu firmwarenya R1A081 juga. Terus pas gua denger ada upgrade R1L013 gua pergi ke Sony Ericsson yang di Warung Buncit.
Masa upgrade firmware aja HP gua mesti ditinggal selama 2 hari! Udah gitu gua nggak dikasih pinjeman HP lagi.
Tapi, 2 minggu lalu gua dapat info ada firmware paling baru, yaitu R3C002. Terus gua ke Sony Ericsson yang di Pondok Indah (sebelahnya Toys R Us). Alhamdulillah di sini gua cuma nunggu 1-1/2 jam dan T610 gua udah di-upgrade ke R3C002.
Perubahannya lumayan banyak dan T610 gua jadi tambah oke deh.
Ini di antaranya:
a. Menu baru di SMS: Contacts. Dengan menu ini elo menghemat 1 klik waktu ngirim SMS karena di menu baru ini ada pilihan: Contacts, Phone Number, SIM Entries, Groups, Unsaved Number; jadi nggak perlu Look-up lagi.
b. Hasil rekaman suara di menu Record Sound lebih kencang dari sebelumnya, jadi gak perlu nempelin HP ke telinga kalau mau denger hasil rekaman kita. Cuma tetep aja nggak bisa dijadiin ringtone.
c. Ukuran file hasil jepretan kamera dengan kualitas yang sama jadi lebih kecil. Lumayan menghemat memory.
d. Hasil jepretan kamera jadi lebih bagus lho...!
e. Khusus sewaktu pake T9, kalau nge klik joystick nggak lagi langsung ngirim SMS, tapi meng-accept kata yang udah kita buat.
f. Waktu nge-play lagu2 di menu Sound, sekarang lagunya diputar langsung dengan suara kencang, nggak pelan-pelan dulu kaya sebelumnya. Tapi kalau dijadiin ringtone tetep aja masih ada elektronik ring dulu (pelan-pelan dulu).
g. Vibration/getar sekarang juga aktif di menu calendar/timer untuk calendar tertentu yang ada task/appointmentnya dan timer yang udah disetting.
h. Ada tambahan bahasa Indonesia dan Malaysia, bahasa China hilang.
3. Gua udah tahu cara bluejacking dari forum di esato (elo bisa cari sendiri kan?) Cuma belum pernah berhasil aja, karena kebetulan gua belum pernah ketemu hp lain yang bisa dibluejack.
Oke, mudah2an bisa membantu.
Salam kenal buat elo dan yang lain. Terutama buat penggemar Sony Ericsson.
Gua udah nggak suka lagi sama Nokia. Banyak ketinggalan dibandingin SE.
Masa Nokia yang harganya lebih mahal kebanyakan 4096 colors, MMS-nya cuma bisa ngirim gambar+text (gak bisa suara), polyphonic-nya cuman 4-poly. Pokoknya jelek dan kayanya pasaran banget deh.
Cheers.
Posted: 2003-10-22 20:48:55
Halo Chester_T610
Asik tuh emang R3Cnya. Ada banyak nilai plus emang
Soal Nokia? Emang! Gwe pernah pake 7250i 7650 3650 kok n bener2 kcewa tu! It's not worth the money I've spent Cuma di Indonesia sih lebih banyak yg demen kosmetik tekhnologi
Gwe banyak nulis soal di tabloid n majalah, paling gress abis2an
di PULSA n Cell4Teen Syukur2 diitung jadi market-education
Longlive !!! Mudah2an makin banyak yg melek tekhnologi ya Biar kita2 bisa lebih asik lagi EMS/MMSnya...
Well, Chester_T610, enjoy and have fun with your
I know I do
Posted: 2003-10-24 03:53:52
cg171s Posts: 27
halo, gue juga orang Indo tapi skrg lagi di Melbourne
udah lama sih masuk esato, tapi ga pernah post reply or massage
hehehe...
skrg masih pake T68i, tapi rencananya sih gue mo ganti sama T610 ato Z600... ada saran??
btw, harga Z600 di Indo brp sih, ada yg tau?
ternyata perkembangan HP di Indo tuh jauh lebih hebat dibanding sama di Aussie loh...(akhirnya....)
soal bluejacking, waktu itu gue udah pernah coba di PS, PIM, sama di TA... semua HP yg gue bluejack tuh SE semua (seringnya sih P800)
tapi di Indo lumayan susah cari "korban".. kalo kata gue sih itu karena orang Indo masih jarang ada yg pake bluetooth mereka....
OK deh,
salam buat semua SE mania di Indo
cheers.
Posted: 2003-10-24 06:37:39
