Technical
> msi usb bluetooth key (MS-6967)
@natas222
this is the thread for the bluetooth adapter. the FMA thread discusion can be found here:
http://www.esato.com/board/viewtopic.php?topic=3699&forum=17
anyway, this is how to solve the problem (at least this works for me.)
1. close FMA
2. find the file smsinbox.dat (which is located to wherever you installed FMA) and delete that file.
3. run FMA again. (there shouldn't be any problems anymore)
Posted: 2002-10-11 13:46:00
@* guys who have upgraded to the tecom firmware.
since the tecom upgrade (1.2.2.16) , i had to manually activate the serial port that FMA uses before FMA would connect to my phone.
I didnt have to intervene with the process with the old 1.2.2.15 version from MSI.
is anyone experiencing the same issue here? workarounds?
TIa
Posted: 2002-10-14 10:44:00
gowin... ill check it out later.. i forgot whats the sequence before..
after 2 days w/ the new sw, i got blue screen again, i have to reinstall the sw last night.
Posted: 2002-10-14 11:01:00
gowin- i dont have to manually activate my serial port on the my bluetooth place. if i click SEND on my fma, it auto connects my bt.
Posted: 2002-10-14 18:35:00
How come you guys get to install this TECOM software successfully?...I can't it seems...I have a MSI bluetooth with software version 1.2.2.4 and 1.2.2.15, also did downloaded 1.2.2.16 from TECOM...But, can't get it install successfully...I have tried it on W2K and XP too...same result...Is it not support for this windows version ?....Pls help....thanks very much...
Posted: 2002-10-15 08:08:00
How? can you tell me the way to do send file from t68 to PC (step by step, pls)?
Quote:Poster: eddwoo
Me Too!!!
At last it all works properly
Well done Widcomm and Tecom
version 1.2.2.16 does the job
others on tdk, msi, billionto etc. should be able to get it to work as well.
Posted: 2002-10-15 08:20:00
@619
hmm ... that's weird. how different is our settings?
btw, once i got it activated and close FMA. re-launching FMA won't require me to re-activate the seria port
@se68
I use w2k. No problems here, check my latest posts
[ This Message was edited by: GOwin on 2002-10-15 07:26 ]
Posted: 2002-10-15 08:21:00
i also had a hard time installing the old version... but not that much w/ the new version; try to take off the bt and uninstall... then re-install.
Posted: 2002-10-15 08:22:00
gowin.. i think our settings are the same, as i based my settings on yours.
Posted: 2002-10-15 08:29:00
GOwin,
Do u uninstalled the previous MSI software version first then install the version 1.2.2.16?...tq
Posted: 2002-10-15 08:37:00
