Sony Ericsson / Sony : Software, Firmware and Drivers : K750 / W800 Firmware Overview
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > K750 / W800 Firmware Overview Bookmark topic
Page <  123 ... 373839 ... 686687688>
mastrmind Posts: 4
Mine is also unbranded. Here is what mine has:
HL1_125952-EU1-MR1_000000_0000_R1J002, 10,640,537 bytes
HL1_125953-EU3-MR1_000000_0000_R1J002, 1,282,639 bytes
I put them up at http://www.tc.umn.edu/~canf0015/se_firmware/
I also think it seems possible that as long as the main firmware is the same, that it should be possible to use a different customization file. I currently have a Europe_3 firmware from MyWorldPhone and would definitely like to get a different one so I can silent the annoying camera shutter.
Posted: 2005-06-14 19:58:19
gbrooks3 Posts: > 500
hehehe,
Watch out you dont screw up the EROM in new K750 phones. Also watch out for FOTA
Problem is that, your DCU-60 cables can utilize the FOTA part of flash meaning that you can only use that cable for Software Upgrade not decustomization. However, if the operator uses main firmware to customize the phone it is possible in theory. But decustomizing/Language changing with SEUS aint happening right now with these phones.
Posted: 2005-06-14 20:14:05
bart_bv Posts: 7
ok. Got the files. The large fil is not identical, so i revised my tactics
I restarted the update process in recovery, let it download the files, then swapped them with the unbranded files (after renaming like the previous ones...)
18% updated so far....
(cross fingers :|)
Posted: 2005-06-14 20:22:47
mastrmind Posts: 4
gbrooks3 -
I searched for FOTA and you are the only person I saw that has mentioned it. What is that? I realize that flashing the phone with an incorrect firmware might disable the phone, but I am guessing it would be similar to having a failed update, you could use recovery mode to flash the correct firmware back.
bart_bv -
Goodluck!
Posted: 2005-06-14 20:28:55
Hobbes Posts: 249
Let us know how it went
Posted: 2005-06-14 20:37:06
Xajel Posts: > 500
mine also unbranded
Big file ( 10392KB ) : HL1_125952-EU1-MR1_000000_0000_R1J002
Small File ( 1247KB ) : HL1_125953-EMEA6-MR1_000000_0000_R1J002
I thought I can flash it as I replace these file with the want-to-put ones before the final update steps ( disconnect-turn off-wait 20 sec.-hold c and connect)... and if any error message appear I may try to rename files...
I don't think I'll try this one
Posted: 2005-06-14 21:00:09
theunknown04 Posts: 43
he is another thing if u look at this site and copy the picture from mckinley he's software is different from the first one and the new one out any 1 know what thats about??more then 1 new one?? the site
http://www.esato.com/board/viewtopi...92330&start=660
Posted: 2005-06-14 21:01:37
Vipera ammodytes Posts: > 500
i have e-plus branded phone can i update my phone????
Posted: 2005-06-14 21:06:06
@bart_bv
What was the result? I hope you dont get configuration error after the update.
Posted: 2005-06-14 21:17:36
SE-Naz Posts: > 500
Just to let all know... another memeber to successfully upload upto date firmware on my unbranded K750i.... YEA!!!!!!!!!!!!!!!!!!
ENJOY
Posted: 2005-06-14 21:26:49
