Sony Ericsson / Sony : Software, Firmware and Drivers : K750i debranding possible with DaVinci
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > K750i debranding possible with DaVinci Bookmark topic
Page <  123 ... 373839 ... 727374>
GsMen Posts: 133
On 2005-07-15 16:41:13, ronymd wrote:
duh never open your phone....unless you want to get rid of warranty.....bye...
This is nonsence. Also I reffer to people that are capable! Many people can open a phone without anyone can see/know it was opend :s
Posted: 2005-07-15 21:49:56
ronymd Posts: 52
@Gsmen
so what is the purpose of opening, i mean what does it do to the phone after (im just curious) ?thanks
Posted: 2005-07-16 03:40:45
GsMen Posts: 133
On 2005-07-16 03:40:45, ronymd wrote:
@Gsmen
To attach direct power source, some people seem to have difficulties to attach phone to davinci, or seus, I (think!) its related to battery. Appying a direct source would 100% determine that
Posted: 2005-07-16 09:27:35
pverri99 Posts: 5
Hey,
I'm going to attempt this once I find 2 cables which are able to connect...
I tried removing the case yesterday but it wouldnt come off. Is there a special technique or something (yes i did unscrew it...)
Posted: 2005-07-16 09:51:02
Tomaso Posts: 48
@nizam.tg
try using IE instead of firefox, had the same white screen problem before (though I havent flashed my phone) it worked for me.... duh never open your phone....unless you want to get rid of warranty.....bye... ...and btw, the SEUs checks both your IMEI and CDA , so even if you flashed the APAC1 fw with EURO_2 fw, after doing update...you're back with the original fw, ....
The IMEI-CDA relationship is real, indeed. Many K750 owners have no need for the CDA modification function of Davinci...
Posted: 2005-07-16 21:04:19
ronymd Posts: 52
@ pverri99
before attempting to remove the cover(even if you are very much capable), first try updating with a fully charged battery.... then if it still does not work, maybe opening the cover might help....
Posted: 2005-07-16 23:05:12
Donnie82 Posts: 2
Could someone confirm does europe4 f/w contain finnish language?
Posted: 2005-07-17 20:17:53
ralfzs Posts: 15
Where I can find CDA options information.
I want to debrand my k750i but have no idea
what CDA to choose. My current branding is E-Plus
Posted: 2005-07-18 12:22:51
synagence Posts: 114
@ralfzs
If you download the new version of davinci it contains a drop-down list of all valid CDA numbers so you just choose the correct region from the list ... so simple now
Posted: 2005-07-18 13:31:21
ralfzs Posts: 15
@synagence
I still need a description what is the difference between
EMEA1,2,3. etc or Europe 1,2,3,. exactly. I found some
info on the net, but the CDA I need is not in
DaVinci's list, because my language is not there.
Posted: 2005-07-18 15:06:57
