Did i just see the transparent bar on Huasan?? o.o
Posted: 2013-01-28 15:49:59
yes you did.
Posted: 2013-01-28 15:51:45
Yay, much better design than the S
I would be better if they make the Top transparent too
Posted: 2013-01-28 15:54:34
Dont agree on better disgn than the Xperia S...
...I think if the Xperia S was more thin it will be the most beutifull phonne ever
I love my Xperia S in white... but it will be replace by a XZ
Posted: 2013-01-28 17:32:02
Don't get me wrong
the S looks great
But it has a pretty useless Plastic bar under the Transparent strip, I know it helps when holding horizontally, but it also makes the device looks bigger than it should be....
For Huasan, they get rid of the plastic and leave only the Transparent strip at the bottom
So in my opinion, it looks nicer
Posted: 2013-01-28 17:45:06
On 2013-01-28 17:45:06, stedus wrote:
(...) Plastic bar under the Transparent strip, I know it helps when holding horizontally, but it also makes the device looks bigger than it should be....
Agree with you... maybe a little less on that final plastic bar, and more thickness of the phone and it would be perfect
Posted: 2013-01-28 18:23:37
Huashan looks like it is a metallic body with a sorta rubberised back (and its got a shutter button yay!!!)
has anybody got a clue about the screen size, dimensions or battery size? would appreciate if you could share it!
Posted: 2013-01-28 18:36:11
@Kewsvnet... No idea abt dimensions... But it might be as thick as Xperia ZL is... And heard that it has 4.3" screen with the resolution of 720p & 1800mAh battery...
Posted: 2013-01-28 18:52:18
thanks for the info! wish battery was a little bigger...but with STAMINA mode it may be able to last long enough
Posted: 2013-01-28 19:05:41
Sony continues to offer some of the best low-end and mid-range phones in the market, Huashan is one hell of a wolf in sheep's clothing
[ This Message was edited by: Detox on 2013-01-28 18:35 ]
Posted: 2013-01-28 19:30:14
