Sony Ericsson / Sony : Software, Firmware and Drivers : k810i dead.only red light near IR blinks
It works!!!!!! Woohoooooooo!!!
Thanks to all posts & forum members, esp Goldmen.
Thanks,
darrkaye
Posted: 2008-09-11 00:23:25
i also have red light blinknig near IR port problem..
i tried XS++ it doesn't detect my phone.. when i connect with C. but if i connect with 2+5 its getting detected but stop at starting point of profiling. so nothing displayed..
if i connect with setool its only getting connected with 2+5 and i'm able to flash it.. but the same problem prevails...
any help would be appreciated..
i found EROM's from
http://iprotebe.cz/sony-ericsson-erom-cid52-section666.html
my phones CID is 52 can i flash the Erom in SEtool..???
or if i update with SEUS will it help me??
Posted: 2009-12-07 10:28:43
i found EROM's from
Update via SEUS do NOT help to repair EROM.
Use XS++ v3.1 (or 3.2) and mark
Flash Main Firmware then choose
K810_RED_CID52_R3B025_EROM-FOTA_2007-07-24_14.bin
Then do NOT turn on your phone, must flash Main with this:
K810_R8BA024_MAIN_GENERIC_SM_RED52.mbn[ This Message was edited by: centur on 2009-12-07 16:15 ]
Posted: 2009-12-07 17:11:57
but the above one is FOTA Erom not a main EROM... somebody told me this in SE-nse so i does this solve the peroblem
and SEUS will update the EROM to CID53 rite??? bec mine is now on 52... so... the problem will be soved
and i tried SEUS i did Repair EROM the press start i got the log file follwed
Seking Ver3.0.4.4
[ --- Identify --- ]
Power Off Phone With Battery, Press C And Plug DCU-60 In...
Phone Connect Success!
Baseband IC ID:9900
Protocol Version:0301
Security Model:FF
Send Applet...
Applet Version:070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J
Flash ID: 0x897E
IMEI: 35170801527360
OTP LOCK: 1
OTP CID: 49
EROM CID: 52
Model: K800i
Main Software Version: R8BA024 prgCXC1250811_GENERIC_SM
Lang: CENT_EUROPE
Operator: ›
CDA: CDA102568/101
CDA Version: R4A
CXC: cxc1250813
CXC Version: R8BA024
Identify Done!
Disconnect Phone Success!
[ --- Initialize --- ]
[ --- Repair EROM --- ]
Baseband IC ID:9900
Security Model:FF
Send Applet...
Applet Version:061220 1711 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3K
Send Applet...
Repair EROM Done!
UseTime:9sec!
this is done is 3 sec.. does this mean my EROM repaired???
[ This Message was edited by: idumbakumar on 2009-12-16 14:44 ]
Posted: 2009-12-16 15:16:58
