Page <  123 ... 420421422 ... 184118421843>
motvikt Posts: > 500
On 2013-02-11 14:01:00, napahlm wrote:
Is that correct? Does the C360X have Adreno 225 while the others have Adreno 3XX (wich i assume is better!?)
225 is better than 305
Posted: 2013-02-11 14:20:21
lewko Posts: 30
So then C360X looks more like P successor with 4.3 inch display and S4 dual....
Hope they dont make it too big.
C550X/560X should be then S/T successor with 4.6 inch display and slightly over-clocked S4 and opticontrast panel
C260X would be a mixture of U and J with 4 inch screen...
Hopefully they dont make C360X too big (idealy a metal housing) and it is a clear Go for me...
Posted: 2013-02-11 14:29:05
DACHA Posts: > 500
On 2013-02-11 13:40:43, Platia1 wrote:
C550X looks like a good handset for people who find the Xperia Z/ZL too large, identical specs aside from screen resolution by the looks of it. I'm looking forward to seeing that, and a possible release date.
[ This Message was edited by: Platia1 on 2013-02-11 12:42 ]
This will be the phone to beat at MWC. Water resistant, aluminum body and very compact. A smaller Z.
Posted: 2013-02-11 15:33:17
bronxdude Posts: > 500
C550X's cam is 13mp exmor R or RS?
Posted: 2013-02-11 16:11:20
-16- Posts: 114
C550X with 2GB RAM and Exmor RS would be perfect. But I think it's a good device with this specs, too.
Posted: 2013-02-11 16:19:59
semo Posts: 182
Mobile-review says MediaTek chips are to be used by Sony soon.
Any ideas about which ones? Entry level? C210X or even more entry level?
Edit: Actually it will be used in several products, they say.
[ This Message was edited by: semo on 2013-02-11 15:25 ]
Posted: 2013-02-11 16:22:29
Exmor R. As for Mediatek, at least as of now there is no phone that uses them
1H 2013 range is 100% Qualcomm based
[ This Message was edited by: randomuser on 2013-02-11 15:31 ]
Posted: 2013-02-11 16:30:06
Sounds amazing, can't wait.
Posted: 2013-02-11 17:02:54
coolkid8689 Posts: 289
But, isn't Dogo supposed to have 2GB RAM as per rumors...???
Posted: 2013-02-11 18:40:15
Rumtimes Posts: 50
If those specs are correct.. choosing between 1.7ghz huashan and waterproof dogo will suck.
Posted: 2013-02-11 19:06:47
