Symbian phones
> UIQ 3 desktop app !
On 2007-09-11 15:02:45, jensj wrote:
well, i have a problem...
when i press the spacebar to lanch phoneapp, it opens all installed programs???
The developer is aware of this problem and is looking into it as well as some other modifications. The problem also happens if you press ALT+Shift key in Gdesk view.
Posted: 2007-09-11 17:25:35
Hi!
can I just install the clock on a W950i?
If so how can I view it, and leave it on the screen?
Or maybe I have to replace one of my 5 icons with the clock ?
thanks for any help!
Ofiaich
Posted: 2007-09-11 17:57:10
On 2007-09-11 17:57:10, ofiaich wrote:
Hi!
As far as I understand it the clock aspect of the app is a plugin. Therefore you need the main app installed and from there you can use the clock plugin or any other plugin created for use with the app. So no you cannot use the plugin by itself.
Posted: 2007-09-11 18:16:41
Hi dizzle !
thanks very much !
I will try to install all later on my W950i and see how it is.
Ofiaich
Posted: 2007-09-11 18:52:11
@ofiach
if you got to the Gdesk link on handango, there is a section on other apps by the creator of gsdesk.
There is I believe a link to an app called Gclock or something similar...which seems to be a standalone clock app (although I haven't tried it out myself)
*edit* it's called Timeblob
[ This Message was edited by: aqualung on 2007-09-11 18:32 ]
Posted: 2007-09-11 19:28:48
Hi aqualung,
thanks for that! Just tried it. I will try the other applications too..
Ofiaich
Posted: 2007-09-11 20:35:59
i use g clock, works fine and its very nice, recommend to use it guys
Posted: 2007-09-11 20:41:00
londonlad123 Posts: > 500
Can you put icons anywhere you want or is it aligned to a grid?
Anysize icons too?
The only thing thats missing now is a one touch bt and wifi on/off switch and status information, like no. of missed calls, texts, mms, email, date, day, etc
Posted: 2007-09-11 21:09:05
@londonlad123
Yes you can put app icons anywhere you want. Is 3 sizes if icon (small, medium and large) Agree BT and WLAN short-cuts would be a more than welcome addition. Is a great app!
Posted: 2007-09-11 21:24:00
i have found a cool shortcut kind of a bootman like effect. for when you reboot and want multiple apps to start with the press of a single button. just map the apps you want to start to the same key and press your hot key .there ya go. example: assign smp,timeblob,activesync,speedcontacts to the letter 'a' . very handy .
Posted: 2007-09-12 05:07:41
