Page <  123 ... 528529530 ... 184118421843>
JoJotaro Posts: 288
The next flagship will always be better than the previous one. The only question is by how much...
Posted: 2013-03-10 12:58:05
Jubei1 Posts: 99
On 2013-03-10 12:22:01, vivftp wrote:
On 2013-03-10 12:04:58, Jubei1 wrote:
Hmm.. Now there is conflicting info
zomg said Xperia RX is not a flagship. From his comments im guessing he meant it will be more of a Nokia Pureview 808 type of product
No cause for concern. Just because the RX isn't the flagship doesn't mean the One Sony phone can't use the same camera tech.
I'm hoping he'll clarify some details for us though.
If 2H flagship uses the same camera tech then what would be the point of the RX in the first place? I can buy that it uses the same Bionz software but the same sensor? Unlikely, the 2H flagship will need to be thin and light because it serves a different type of consumer compared to a camera focused phone
Posted: 2013-03-10 12:59:49
JoJotaro Posts: 288
There's no way it comes close to the RX100 imo. But using an adaptation of the tech used in the RX100 for a phone will help improve camera quality by a lot imo.
Posted: 2013-03-10 13:03:26
Xajel Posts: > 500
Just FYI guys, thought larger sensors in general means better quality duo to larger pixel size ( = less noise ), but larger the sensor, the thicker the device must be... duo to larger focal length. if you don't want it to be thick then you have to add a telescopic lens like in most point and shoot camera's as they are slimmer than the required focal length for the sensor, so they adds a telescopic lens that opens when turned on to get the required focal length...
See the Pureview large sensor required it to be thick, at least in the sensor area...
Posted: 2013-03-10 13:04:31
jianlin Posts: 489
would H2 flagship get s master and stereo speaker?
http://www.sony-asia.com/prod[....]productcategory/pa-mp3-walkman
seem like only left s master , noise cancelling and Digital Sound Enhancement Engine (DSEE) haven got in xperia phone...
[ This Message was edited by: jianlin on 2013-03-10 13:07 ]
Posted: 2013-03-10 13:59:45
vikeviki Posts: > 500
^^ love to see this tech soon
Posted: 2013-03-10 14:14:00
With proper processing it's possible for a 1/2" sensor to beat even the larger 1/1.2" of the 808 in image quality, we've seen that on digital cameras like the M43 equipped OMD E-M5 mirrorless from olympus by which the sensor was made by Sony, bravely clashing with APS-Cs like the NEX lineups and even entry level Canon EOS DSLRs in high ISO performance. but what gives me doubts was not the Sony hardware, but the software itself. Sony is infamous for their inferior JPEG processing (even in DSLRs) and even with better light sensitivity, I'm not sure it'll beat 808 pureview. I'd personally prefer a larger sensor, as it gives us shallower depth of field which is perfect for portraits and macro. and I'd personally be happier if Sony decided to put android on an RX100 body to compete with the galaxy camera while retaining most of the features including the sensor size and that high quality F1.8 Zeiss T* lens. IMHO Slim phones are overrated, especially if people would end up enclosing their slim phones on 3rd party jelly case or jacket, defeating the point of its slimness
[ This Message was edited by: razec on 2013-03-10 13:40 ]
Posted: 2013-03-10 14:37:37
JoJotaro Posts: 288
But there's a limit to thickness too when you want something to be pocketable. The PureView 808 imo is a bit to thick.
Posted: 2013-03-10 16:00:03
itsjustJOH Posts: > 500
The 808 is pocketable, but I wouldn't want the Xperia RX to be that thick.
Anyway, I found this.
Source: Image Sensor Format
Posted: 2013-03-10 16:16:58
DACHA Posts: > 500
Update on DOGO
Dogo is the combination device of the Z and ZL. It will be one of the H2 flagships.
SPECS
5" full HD display
Snapdragon 800
16MP camera.
2GB RAM
Smaller than ZL
The other H2 phone is considered a camera phone and not a flagship but it will cost more than the flagship because of the camera features. This phone will be very similar to the Cyber-Shot phones and it will be more focused on the camera side of the phone rather than being a flagship. It will also be on the thick side because of the larger camera sensor.
Posted: 2013-03-10 19:11:54
