Page <  123 ... 568569570 ... 184118421843>
MtLeakerDev Posts: 150
I hope they consider the phone size
It should be at least like
140 x 71 I don't care about thickness
But ramu mentioned it would cost 1000$
Is that true?
Posted: 2013-03-16 07:44:29
drsoran2 Posts: 66
so it seems like that all the Sony phones coming out in the rest of the year will be with 5" screen? If you want something smaller, you'll have to settle for low specs or the C550X Dogo which appears to have good specs and a 4.7" screen. Is that right?
Posted: 2013-03-16 09:06:52
vivftp Posts: > 500
On 2013-03-16 04:41:27, jianlin wrote:
One Sony Features ( rumored )
- x reality
- carl ziess
- Bionz
- Exmor
- Big sensor
- f 2.0
- s master mx
- IP rating
- IR blaster
+ those Z features....
curious about material used though...
hoping for
Wet Finger Tracking
Floating Touch
dedicated camera button
[ This Message was edited by: jianlin on 2013-03-16 03:57 ]
These rumored specs make me all warm and tingly inside
In addition to them, for the rumored $1000 or so price range I would hope to see 64 to 128 gigs of on-board memory, a shutter button,, and a display whose quality is good enough that no one could complain about it. It would be cool if it could have the stylus of the phablet too, but I suppose that won't happen. It would also be interesting if this phone also had some sort of drop rating just like it has a water and dust rating, but that might be asking too much. Wireless charging would also be great.
Another thought occurs to me. If the phone will be thicker to accomodate the bigger camera, that means they should have more space for a far larger battery too. Any info on whether they are going for a monster battery in this bad boy?
If they can put all of the above into a single phone then I would gladly pay $1000 for such a beast. Hopefully I could get it subsidized by my carrier though.
[ This Message was edited by: vivftp on 2013-03-16 08:30 ]
Posted: 2013-03-16 09:28:00
jianlin Posts: 489
ramu say 3000mah...but it should have 3500mah..haha...since razr maxx hd 3300mah in 9.3mm...
Posted: 2013-03-16 09:30:58
vivftp Posts: > 500
3000mah is not too shabby as the s800 processor is supposed to be more energy efficient than s4 pro or s600, plus a white magic display should conserve power too.
Also, forgot to add to my wish list above that I hope for a xenon flash too. If they are making such a beastly phone with a kickass camera, it must have a xenon flash!
Posted: 2013-03-16 09:36:38
jianlin Posts: 489
hope that it is compact too...as ramu say max thick is 12mm is all right for me..haha...twin flashlight is ok too...
[ This Message was edited by: jianlin on 2013-03-16 08:44 ]
Posted: 2013-03-16 09:43:16
Believe me it's not about thick
It's about tall and wide xD
Posted: 2013-03-16 09:46:07
vivftp Posts: > 500
For it to gain any level of mainstream appeal it will need to be relatively thin, but I don't mind if it's 12mm thick. BTW, are we still speculating that One Sony will be smaller than the ZL in the other dimensions?
Posted: 2013-03-16 09:47:58
jianlin Posts: 489
i do care about weight...max 160g pls...haha
Posted: 2013-03-16 09:54:51
One Sony may be about the same as Z or 1-2mm longer and wider at max. Weight won't be more than 160
And yes, seems like Xenon Flash is on the cards for One Sony (XR2)
Posted: 2013-03-16 10:02:01
