Sony Ericsson / Sony : Symbian phones : UIQ 3 desktop app !
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > UIQ 3 desktop app ! Bookmark topic
Page <  123456789>
jensj Posts: 16
Is there any way to add a shortcut to main menu?
Posted: 2007-09-12 15:15:35
marran Posts: 272
Yes, if you first enable "showing system apps". Then you'll find main menu in the list.
Posted: 2007-09-12 15:31:28
xoo88 Posts: 108
thanks for your great hints !!! really work and useful !!!
On 2007-09-12 05:07:41, jortiz1200 wrote:
i have found a cool shortcut kind of a bootman like effect. for when you reboot and want multiple apps to start with the press of a single button. just map the apps you want to start to the same key and press your hot key .there ya go. example: assign smp,timeblob,activesync,speedcontacts to the letter 'a' . very handy .
Posted: 2007-09-12 15:44:36
ralliart_rob Posts: 4
This app is great. I've got a small problem though. I can no longer set the lock by holding the back button on the side of my W950i. Am I missing something?
Thanks
Posted: 2007-09-12 16:43:44
ofiaich Posts: > 500
Just took a photo of my W950i !
My lock button also exits the application !! But I can lock by using the drop down menu at the top left of the screen...
Ah!! I just received a call and when I finished the call, GDesk exited..
But screen looks nice, more to check out...
Ofiaich
[ This Message was edited by: ofiaich on 2007-09-12 16:04 ]
Posted: 2007-09-12 16:57:19
Thanks ofiaich
I've lost my stylus so it's a bit fiddly to access the dropdown list in the left hand corner. Guess I can live with the automatic lock timer function. Would just have been nice to still be able to lock with the back button when in a hurry.
If you "Replace Main" in the options list of GDesk it should go back to your desktop after you receive a call. Mine did anyway.
Cheers
Rob
[ This Message was edited by: ralliart_rob on 2007-09-12 16:10 ]
Posted: 2007-09-12 17:07:55
Thanks too ralliart_rob!
I can just get at that drop down menu with my finger nail....
Thanks for telling me about "replace main"
what do you do if you want to restore after " replacing main" ?
I guess if I try it, I will see a different menu item appear? Restore?
Hahaha! stupid me ! Yes, just uncheck it...!
Ofiaich
[ This Message was edited by: ofiaich on 2007-09-12 16:15 ]
Posted: 2007-09-12 17:14:45
lost17 Posts: 17
New version 0.11 available from Gary with this fix list:
Added default page selection
Fixed jog operation bug
Split ‘override main’ for flip open/closed
Added ‘assign key’ to page link
Fixed ‘space bar craziness’ bug
Removed title bar but kept self-glorification message
Reduced memory footprint by over 400kb
Fixed a couple of crash bugs
Made safe mode -really- safe
Added ‘max fit’ and ‘no fit’ options for image conversion
Widened sub-menus
Removed desktop reload on re-activation
AgnView: Added time column
AgnView: Made column widths more constant
Downloaded just now from Handango ... very good job Gary !! Thanks
Posted: 2007-09-14 08:52:09
having a look now,
but should the previous version be uninstalled ? Or will this version just overwrite it ?
I am also wondering what the .gdd files are? Where to install them ? I am using a W950i !
Thanks for any advice!
Ofiaich
[ This Message was edited by: ofiaich on 2007-09-14 19:14 ]
Posted: 2007-09-14 20:10:54
marran Posts: 272
the gdd files are different themes.
You can save and load different themes .
Here is mine if someone has a hard time creating a style.
(I should mention that it's adapted for the uiq-theme: Rising sun.)
http://files-upload.com/files/502800/rising%20sun.gdd
Posted: 2007-09-14 20:58:30
Page <  123456789>
