UXP is user experience or user interface. Its really simple no need to be confused
[ This Message was edited by: kurtdean on 2013-04-05 12:21 ]
Posted: 2013-04-05 13:19:03
On 2013-04-05 13:09:10, itsjustJOH wrote:
On 2013-04-05 12:15:18, nightwing369 wrote:
Thanks but that links to the user interface used in the Xperia S using Android 2.3 and/or 4.0. There is a slightly different one used from the Xperia Z onwards... ?
Dude, UXP is Sony's UI. Do you need that written on a billboard for you?
Edit:
@ramu
Is the new UXP exclusive for the new Sony smartphone lineup? And would it be a major overhaul or just some minor design tweaks?
[ This Message was edited by: itsjustJOH on 2013-04-05 12:14 ]
Close to a major overhaul. Like the jump from 2011 to 2012 UXP. The second major jump since Sony Mobile's inception.
[ This Message was edited by: randomuser on 2013-04-05 12:27 ]
Posted: 2013-04-05 13:26:46
@Randomuser
Is the Z slated to get the New UI in the update?
Posted: 2013-04-05 13:33:06
On 2013-04-05 13:33:06, Karun wrote:
@Randomuser
It's too early to answer that. Perhaps even Sony doesn't have the answer as of now
Posted: 2013-04-05 13:40:18
@Randomuser
The new UI will be heavily customized right?
Will it affect the update speed of future Sony devices? since it might take more time to implement the UI to newer Android version
Posted: 2013-04-05 13:51:20
Not at all. Light skin as Sony tradition is
Posted: 2013-04-05 14:02:23
The Sony skin on my X10 mini pro was quite heavy actually to be honest - before I custom rom'ed it
Posted: 2013-04-05 14:06:33
That's a great news
) can't wait to see this new UXP
Posted: 2013-04-05 14:08:53
Is it closer to stock Android? Imo the closer to stock the better, 'cause it should be easier to update and lighter = faster... Just added features and applications/widgets...
[ This Message was edited by: JoJotaro on 2013-04-05 13:18 ]
Posted: 2013-04-05 14:13:48
Thank god such a relief.Is it closer to stock Android??
Dont want Sony to screw up the future updates with heavy UI now.
Posted: 2013-04-05 14:25:42
