On 2013-04-12 21:57:49, JaroB wrote:
Samsung Galaxy MEGA 5,8 = 2600mAh
Samsung Galaxy Mega 6,3 = 3200mAh
Xperia Phablet Z 6.33" = 3000mAh ..... not bad : Ta:
[ This Message was edited by: JaroB on 2013-04-12 20:58 ]
Actually, it's pretty terrible considering the S4 will ship with 2600. That's a 500mAh increase over the S3 and it's a phone with a 40% smaller screen area than the phablet (if the 6.44" spec is accurate). To be comparable it would definitely need a whitemagic display; something to reduce the drain of that panel. It's also going to be interesting to see if the use of SD800 increases or decreases power draw.
I mean it's less than the current Note 2. If the Note 3 (which I suspect would be its main rival) ends up getting the same % increase in battery capacity it'd have around 3700. The Ascend Mate has 4050 mAh (and it's not even powering a 1080p panel).
Seems like a big tradeoff for thinness. It's going to be interesting to see how this pans out.
[ This Message was edited by: RumrCollectr on 2013-04-12 23:34 ]
Posted: 2013-04-13 00:33:41
On 2013-04-12 16:54:56, randomuser wrote:
Potentially BAD news.
[XR5]Xperia phablet may be equipped with only 3000mAh battery.
That's the battery size on current prototypes under testing
[XR3]And One Sony camera sensor size is between 1/1.8" - 1/1.5"
[ This Message was edited by: randomuser on 2013-04-12 16:12 ]
I can't critic for the battery capacity for Xperia phablet,I have to see the whole specs first.
Posted: 2013-04-13 04:11:45
On 2013-04-12 20:49:13, moogoo wrote:
what's the reason for using two types of glass instead of just dragontail on front and back? is it cause of lack of supply?
also, not really sure what it means as far as sensor size in the One Sony. Sony has always made great sensors. It's their post processing that has been poor. That's something I'd like to hear is getting a re-vamp with new algorithms and such.
Yes, One Sony uses all new picture processing algorithm
Posted: 2013-04-13 05:50:26
sony used latest sensor on Xperia Z/ZL but not latest module! (F2.4 for Xperia Z/ZL) But samsung used latest (F2.2) ...
Posted: 2013-04-13 06:03:51
ya other chinese brand also f2.2/f2.0
only sony f2.4
glass also samsung give latest gorilla 3
Posted: 2013-04-13 06:17:29
On 2013-04-13 08:58:54, aurelius wrote:
phablet CA week 30, delayed.
No words on jb for XS
Honami very sonyish, my source have seen it
Is there any specific reason(s) for the phablet delay?
Posted: 2013-04-13 09:02:03
week 30= July 22, 2013 to July 28, 2013
Posted: 2013-04-13 09:03:26
If they goes for IGZO = 3000 mAh will be more than enough
Posted: 2013-04-13 09:16:36
Will One Sony AKA Honami be thick?
Posted: 2013-04-13 09:41:10
Except it seems that they're not.:
On 2013-04-08 09:26:42, randomuser wrote:
Phablet will use JDI panel. Same as the Ion/TX screen quality and specifications wise. So viewing angles still not "stellar"
[ This Message was edited by: RumrCollectr on 2013-04-13 08:59 ]
Posted: 2013-04-13 09:57:36
