Sony Ericsson / Sony : Symbian phones : Will I be able to use my P800 with my BMW?
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > Will I be able to use my P800 with my BMW? Bookmark topic
Page <  123 ... 78, 91011>
zabir Posts: 20
I have just heard from BMW today that the BT kit works well with the Nokia 6310i but she wasnt sure if it would work ok with the P800. What she did say was she was going to get me a demo car which had BT fitted for me to try out. So if anyone is interested I will post back here my results hopefully tomorrow or saturday.
Posted: 2003-09-11 18:42:54
Jah Posts: > 500
@zabir
I'm not thinking of buying a car with BT at the moment (may think about this next year for my wife) but I think it would be good to hear which cars have BT kits that work with the P800. Knowing which BT kits support P800 is legitimate information, IMO, for this forum.
Posted: 2003-09-11 21:14:22
zabir Posts: 20
Just thought I would let those of you know who are interested,
The P800 doesnt work with the BMW BT, The T68i does but not the p800.My local dealer will be sending BMW HQ an e-mail to see what they can do about it.
Posted: 2003-09-12 18:28:23
fijbert Posts: > 500
sux
the P800 BT does suck....
Posted: 2003-09-12 18:34:20
jbendaou Posts: 458
Nothing can be done about it. there is no profile in the P800 therefore it wont work...maybe this will be possible if in some upgrade for the P, the profiles were added, till then, get a t610 and when the new p810 comes or even p800 upgrade(with profiles), then get it.
Posted: 2003-09-12 18:49:26
Sage Posts: 233
Hi i have a Lamborghini Dioblo VT SE Customized 2004 Edition Car with a type v-12 60 degree, light-alloy block, mid-mounted, rear-wheel drive dual camshaft chain drive 4 overhead valves with a cyl capacity of 5992 cc and max power of 550 hp at 7100 rpm and max torque of 620 nm at 5500 rpm. The chassis frame is a steel rectangular high strength allow and copmposite carbon fiber. The Body is aluminium alloy and hand layup composite materials. Front and rear suspension indipendent double wishbone. Brakes are self-vetilating discs on 4 wheels with abs system lucas variety double hydraulic circuit. Front tyre size is 235/35 zr 18 rear tyres are 335/30 zr 18 Chassis types is pirelli p zero. Length is 4470 mm width 2040 mm hieght 1105 fron track 1610 mm rear track in 1670 mm dry weight is 1625 kg and top speed is 330 km.h 0-100 km/h in 3.95 secs. Most advanced navigation system built in with (alpine) with dvd, cd, dvd changer, cd changer huge speakers in back, live satelite television, parrot bluetooth kit, fm am radio, internet through gprs satelite, and wifi (3g) at 1.5 mgbits (which exists in the states and is provided by my father actually ). Screen is provided for both front seats. Now I was wondering whether i could bring my p800 into the car and if i can put it into the cup holder! LOL and no i do not own this car (yet!) arg! I am just a couple thousand short of the down payment and another 100k of payments lol
Posted: 2003-09-12 22:40:31
__spc__ Posts: > 500
@Sage
That motor is so not worth it - I bought my wife one, just so she could pop down the shops etc. when we run out of caviar, but the just sucks. I'd go for some poxy Beemer, say, a 330Ci or something like that...
Posted: 2003-09-12 23:38:12
ainamrev Posts: > 500
Wonder what car i should buy before my next trip to Tesco's i need something with bluetooth simply so i can buy stuff from argos with all my money with out taking my hands off the wheel and i wont have to pull my precious styli from my anus to tap in the number!
Posted: 2003-09-13 00:15:04
chubnut Posts: 76
I don't know who manufactures the BT kit for BMW, but I had the SE one put in my BM'er and it works fine. It also works in the Land Rover...... So couldn't you just get BMW to put the SE one in instead of ....dare I say it.... an obviously pants piece of kit of theirs. Seems like an easy soloution.
[ This Message was edited by: chubnut on 2003-09-13 00:59 ]
Posted: 2003-09-13 01:57:49
Sage Posts: 233
lol yeah i tried to take in my p800 but it wouldnt fit properly inot the cupholders as well as the crapy bluetooth. Oh well ill just have to settle for the December 2003 edition
Posted: 2003-09-13 17:31:55
