Page <  123 ... 742743744 ... 184118421843>
vikeviki Posts: > 500
On 2013-04-29 16:01:34, DACHA wrote:
Xperia UL (Gaga)
5" FHD
APQ8064 (1.5GHz, quad-core)
2GB
Dust-proof and waterproof
IR
Removable 2300mAh battery
Slightlyt short than Z same width as Z and thicker than Z
Illuminated Sony logo
Summer release
Xperia A (Dogo)
Same specs as UL except
Smaller display 4.6" HD and smaller in size.
Also XA will be released before UL.
Xperia Honami
Snapdragon 800 MSM8974 2.0Ghz
5" IPS display(most likely IGZO-IPS)
16MP camera with LED (nothing close to Nokia 808 PureView)
2GB RAM
2650 mAh Battery
Global release in September/October (including Japan)
Dacha00000000000000000000wwwwww
not exciting
[ This Message was edited by: vikeviki on 2013-04-29 15:34 ]
Posted: 2013-04-29 16:33:24
geniusming Posts: 36
Xperia Honami
2GB RAM
2650 mAh Battery
if this is real, Honami seems only with better outlook and camera...
2650 mAh is similar to S4 (but S4 is removable battery...)
I think on Sep when it launch, many phones can get similar spec with this...
Posted: 2013-04-29 16:36:42
nightwing369 Posts: 415
Will the Sony Dogo will have 8GB, 16GB or 32GB internal storage?
Posted: 2013-04-29 16:37:45
maloqs Posts: 275
Well that specs should be come at lower price.
Processing speed is ok.
Battery Life hmm.....Same or better than Z by a little....
Camera is generally ok.
[ This Message was edited by: maloqs on 2013-04-29 15:46 ]
Posted: 2013-04-29 16:38:57
If the Dogo (Xperia A) releases before the UL (Gaga), then in that case, in which month?
[ This Message was edited by: nightwing369 on 2013-04-29 16:11 ]
Posted: 2013-04-29 16:38:58
MartenR Posts: 313
@Dacha
are you sure about your info?
Posted: 2013-04-29 16:43:44
DACHA Posts: > 500
On 2013-04-29 16:43:44, MartenR wrote:
@Dacha
That is the info I got. Time will tell if it is right or not. Sony might surprise us all.
Posted: 2013-04-29 16:48:57
maloqs Posts: 275
^ lol dacha u got almost correct everytime.....
Posted: 2013-04-29 16:49:55
maiaramdan Posts: 308
Xperia UL (Gaga)
5" FHD
2GB
IR
Summer release
Xperia A (Dogo)
Xperia Honami
2GB RAM
2650 mAh Battery
Hi Dacha , sorry do not enter as before
you are right about the specs , even what you said it is Honami
but from what i know this what you said about Honami in specs will be a cheaper version of the Xperia One
as SONY will have 2 versions
2GB RAM
2650 mAh Battery
and the Other one
Snapdragon 800 MSM8974 2.3Ghz
20MP camera
4GB RAM
3000 mAh Battery
with the same Global release dates
i saw it's architecture at UK in february
Posted: 2013-04-29 17:06:21
maloqs Posts: 275
TY maia thats THE MYSTERY VERSION that randomuser SAID!
Posted: 2013-04-29 17:07:50
