On 2013-04-29 17:06:21, maiaramdan wrote:
On 2013-04-29 16:01:34, DACHA wrote:
Xperia UL (Gaga)
5" FHD
APQ8064 (1.5GHz, quad-core)
2GB
Dust-proof and waterproof
IR
Removable 2300mAh battery
Slightlyt short than Z same width as Z and thicker than Z
Illuminated Sony logo
Summer release
Xperia A (Dogo)
Same specs as UL except
Smaller display 4.6" HD and smaller in size.
Also XA will be released before UL.
Xperia Honami
Snapdragon 800 MSM8974
2.0Ghz
5" IPS display(most likely IGZO-IPS)
16MP camera with LED (nothing close to Nokia 808 PureView)
2GB RAM
2650 mAh Battery
Global release in September/October (including Japan)
Hi Dacha , sorry do not enter as before
you are right about the specs , even what you said it is Honami
but from what i know this what you said about Honami in specs will be a cheaper version of the Xperia One
as SONY will have 2 versions
2.0Ghz
2GB RAM
2650 mAh Battery
and the Other one
2.3Ghz
20MP camera
4GB RAM
3000 mAh Battery
with the same Global release dates
i saw it's architecture at UK in february
Are they both 'International' releases or is one of those [unfortunately] Japan only?
Posted: 2013-04-29 17:10:24
@randomuser
What do you think about Dacha's info and honami?
@Dacha
Do you know anything about price range of Xperia UL and A?
Posted: 2013-04-29 17:15:04
So, Honami is the one that fits between the phablet and One Sony?
Posted: 2013-04-29 17:21:44
Honami
is One Sony
check this:
https://docs.google.com/sprea[....]0ZiNzZQcjMwV1I5M0E&usp=sharing
Posted: 2013-04-29 17:24:10
what i saw in February and told to guys about was 2 versions
at this time ago i was thinking they will choose between them
but maybe they will make them both and may be they chose the less spec
but the one with the 16MP it is the same sensor as the Z , not a large sensor
the large sensor was in 8MP for mid range and 20MP
Posted: 2013-04-29 17:32:11
In that document, it is. Unless you're an insider, you should let our insiders answer our query.
Seems consistent with what has been shared by DACHA and ramu. Could be C670X if One Sony is C680X? BTW, you mentioned a large 8 MP sensor. What device (phone or tablet) would be using this?
Posted: 2013-04-29 17:37:43
Remember, @randomuser mentioned that it looks as if the C670x is fake. I don't think it will be an alternative One Sony/Honami
Posted: 2013-04-29 17:44:59
Posted: 2013-04-29 18:08:02
2012 story in repeat??
2012 =Xperia T/TX VS Xperia V ???
2013=Honima[16mp] VS One Sony [20mp] ???
Posted: 2013-04-29 18:12:09
@Mairamadan; so do you know for certain if Sony will go with 2 versions of Honami, or one of them?
Posted: 2013-04-29 18:28:13
