I think what aurelius is trying to say is One Sony is just a project, and there and multiple phones under the umbrella.
And that will make much more sense, since One Sony was Kaz's vision or whatever.
Posted: 2013-04-29 18:50:35
On 2013-04-29 17:06:21, maiaramdan wrote:
and the Other one
Snapdragon 800 MSM8974 2.3Ghz
5" IPS display(most likely IGZO-IPS)
20MP camera
4GB RAM
3000 mAh Battery
with the same Global release dates
If you're right about this one:
The largest melt-down in Esato history
Posted: 2013-04-29 20:30:19
One Sony is a motto. The Honami is basically that motto put into effect in the design of a phone.
One Sony is effectively a pet-name for the Honami, as far as I can tell.
Posted: 2013-04-29 20:48:35
I thought One Sony was more of a philosophy. The best of Sony's divisions rolled into everything they do.
Posted: 2013-04-29 20:54:10
On 2013-04-29 16:01:34, DACHA wrote:
Xperia UL (Gaga)
5" FHD
APQ8064 (1.5GHz, quad-core)
2GB
Dust-proof and waterproof
IR
Removable 2300mAh battery
Slightlyt short than Z same width as Z and thicker than Z
Illuminated Sony logo
Summer release
Xperia A (Dogo)
Same specs as UL except
Smaller display 4.6" HD and smaller in size.
Also XA will be released before UL.
Xperia Honami
2.0Ghz
16MP camera with LED (nothing close to Nokia 808 PureView)
2GB RAM
2650 mAh Battery
Global release in September/October (including Japan)
Hi Dacha , sorry do not enter as before
you are right about the specs , even what you said it is Honami
but from what i know this what you said about Honami in specs will be a cheaper version of the Xperia One
as SONY will have 2 versions
2.0Ghz
2GB RAM
2650 mAh Battery
and the Other one
2.3Ghz
20MP camera
4GB RAM
3000 mAh Battery
i saw it's architecture at UK in february
Don't believe that for a second. Stop pretending to be an insider. The difference in manufacturing cost between the two would be like ~10$. Hardly a cheaper version. Would make ZERO sense to have two versions
Posted: 2013-04-29 21:08:45
DACHAS specs for Honami is still a damn good phone.
Posted: 2013-04-29 21:26:41
Will Honami be picked up by US carriers (as in more than just ATT)?
Posted: 2013-04-29 22:10:42
Spectre51 already confirmed that it is not coming to AT&T. T-Mobile or Spring might get it. Spectre51 should have very accurate info on that.
Posted: 2013-04-29 22:20:26
http://www.iosdoc.com/iphone-5s-camera-dual-shot/
another phone with dual shot after s4 and g pro...hope sony will bring more feature to the camera on One Sony
Ideal One Sony Spec (Best of the best)
@ My Wishlist
-5" 1080P display JDI WhiteMagic or Sharp IGZO. Likely 2000:1 contrast with Triluminos + X Reality
-Gorilla glass 3 / Dragontrail / any better glass with Floating Touch + Wet Finger Tracking
-3/4 GB RAM
-32gb internal with micro sd slot
-S800 2.3GHz + adreno 330
-Water and dust resistant.
-IR blaster
-20 MP CMOS with 1/1.6 large sensor
-3mp front camera with great lowlight shot ( BB playbook got 3mp front camera )
-Carl Zeiss / Sony G lens
-Improved JPEG compression algorithms...
-(Bionz...SteadyShot....Clear Image Zoom...High Speed Auto Focus..20x zoom.) hope to see these in future Xperia
-Xenon flash / dual LED flash
-Dedicated camera shutter key
-S-Master MX digital amplifier for mobile
-Stereo speaker with S Force Surround
-3000 mah
-illuminated logo + led light strip like zl
[ This Message was edited by: jianlin on 2013-04-30 01:52 ]
Posted: 2013-04-30 01:40:23
hello everyone,
I have been following here since 2011 when I finally replaced my w880i with a white xperia arc s.
I was always to lazy to make an account
my wishlist:
-5" 1080P display JDI WhiteMagic or Sharp IGZO, 2000:1 contrast with Triluminos + X Reality
-Dragontrail glass on front
-Floating Touch
-Snapdragon 800 clocked at 2.3 GHz
-2-4gb ram
-IR blaster
-20 MP camera with a large sensor
-3000+ mah
-Led light strip like zl, led on back of phone too.
-Touch panel on back like on the vita
-Fingerprint scanner
one can dream...........
Posted: 2013-04-30 03:36:02
