On 2013-04-30 10:02:11, sighduck wrote:
Why are the sensors in the diagrams round? Sensors are not round like the lenses...
I was about to ask the same question...It should be rectangle...
Posted: 2013-04-30 11:28:47
On 2013-04-30 11:28:19, Ambivalent_ wrote:
On 2013-04-30 06:19:21, randomuser wrote:
And seems like S800 will be clocked at 1.7ghz on both phablet and one sony. Same with LG Optimus G2. Apparently battery life is affected @ 2.3ghz so all manufacturers are sticking to 1.7ghz.
So One Sony will be nowhere near the fastest phone as it seems that Note 3 will decimate it specs.
Very disapointing!
What?
Note 3 stands nowhere near Honami. Exynos Octa is barely faster than S600. Even 1.7ghz can handily beat 2 ghz Exynos Octa. And the GPU on S800 is 2x faster than Exynos Octa.
Posted: 2013-04-30 12:13:13
So the sensor and lens haven't been finalized yet?
[ This Message was edited by: JoJotaro on 2013-04-30 11:23 ]
Posted: 2013-04-30 12:23:30
They have been finalized.
Posted: 2013-04-30 12:28:55
Carl zeiss is confirmed?
Posted: 2013-04-30 12:42:17
No Carl Zeiss.
Posted: 2013-04-30 12:45:15
On 2013-04-30 12:45:15, randomuser wrote:
No Carl Zeiss.
Thought only Nokia had a partnership with Carl Zeiss for its lenses/sensors? Would be awesome though if Sony had that in one of its phones. Would they be using the best of the best C.Z. sensor/lense, or something fairly high spec nonetheless?
Posted: 2013-04-30 12:50:23
No Carl Zeiss.
Too bad
SONY can't use it because it's exclusive for Nokia smartphones only
Posted: 2013-04-30 12:56:32
Ex Octa barely faster than S600!? Oh c'mon man, Ex Octa scores 5000 points higher on AnTuTu! That's not barely.
So Ex Octa scores 28.000 points with a 1.6 Ghz cloack. The Korean version with it's 1.8 ghz/per core should go pass 30.000 points and Note 3 with 2 Ghz will be in the realm of 35.000.
So, keeping in mind that S600 with 1.9 Ghz scores 23.000, S800 would have to be 50 percent stronger than S600 to be comparable with Ex Octa and all of that would have to be done with lower core frequency.
Here are some links for the data I used:
http://www.ibtimes.com/samsun[....]-600-according-antutu-1183361#
http://www.sammobile.com/2013[....]ills-qualcomms-snapdragon-600/
Posted: 2013-04-30 12:59:32
0.2ghz clock speed increase doesn't give you 5k extra in Antutu. Get real
2.3ghz S800 scores 34000. 2ghz Exynos will score about 30k and 1.7ghz S800 will also score about the same. In most other benchmarks S800 will be faster than Octa and GPU performance is 2x more.
[ This Message was edited by: randomuser on 2013-04-30 12:04 ]
Posted: 2013-04-30 13:01:32
