Page <  123 ... 763764765 ... 184118421843>
sami92a Posts: 423
On 2013-05-01 15:39:31, AbhiD999 wrote:
On 2013-05-01 15:02:38, sami92a wrote:
Honami seems like its getting worse and worse, at first it sounded like a Super phone from Sony. But now it just sounds like " Meeeh" with the new downgraded specs... nothing special anymore
i still don't get which specs have worsened! Honami will most probably have 20mpx sensor with effective 8-13 mpx reso. using oversampling technique...
Regarding the processor...
Clock Speeds r changed even at d last seconds, so nobody knows what will be the final clock speed of the processor
1. the Carl Zeiss lens is gone from the Rumours and Ramu said they are going to use a Sony Lens instead,
2. Sony Screen instead of triliminous Screen
3. 13-16 MP instead of 20 MP, no Xenon Flash
4. 2650 mAh Battery instead of 3000
IMO this is worsened Specs
[ This Message was edited by: sami92a on 2013-05-01 20:58 ]
Posted: 2013-05-01 21:52:38
sami92a Posts: 423
On 2013-05-01 16:54:28, jianlin wrote:
http://mobilizedtech.blogspot[....]ony-xperia-honami-concept.html
nice concept though....
wow really nice! i hope it will look something like this
Posted: 2013-05-01 22:08:36
-XYZ Posts: > 500
A Zeiss lens was always extremely unlikely. If you consider a good Sony designed lens, to be meh, then you need to manage your expectations.
Triluminos was a dream. Extremely unlikely from the outset.
And a 1080p Sharp IGZO display is still vastly superior to the competition. If you think that's meh, the again, you need to manage your expectations.
Do you just like big numbers?
12mp on a 1/1.6 sensor would result in large pixel area (basically 2 microns), resulting in much, MUCH better low-light performance. Xenon flash, Plasma flash or a dual LED flash are fine for me.
When was this said?
Still not seeing the meh. It would be on par with other flagships at worst and from the looks of it, the camera alone would prop it high above most flagships.
Posted: 2013-05-01 22:18:29
nightwing369 Posts: 415
Updated the spreadsheet: https://docs.google.com/sprea[....]PdUFJd0ZiNzZQcjMwV1I5M0E#gid=0
Will the Honami use Dual LED Plasma flash?
Will the Honami use WhiteMagic technology in its display?
Is the Dogo screen definitely 4.65" or is it 4.7" ?
Is the Dogo definitely Xperia ZR instead of Xperia A?
[ This Message was edited by: nightwing369 on 2013-05-01 21:20 ]
Posted: 2013-05-01 22:19:26
sami92a Posts: 423
When was this said?
Dacha updated us with new specs some days ago and there it was 2650 instead of 3000
[ This Message was edited by: sami92a on 2013-05-01 21:58 ]
Posted: 2013-05-01 22:57:15
Can someone provide me some whitepaper or any spec sheet of this so called Plasma Flash? because from the last time I researched on this thing(around 2009), I found out that this was nothing but a silly marketing BS, real Plasma bulbs are excessively hot to be installed on a slim device like a smartphone in which certain models are starting to have issues with heat dissipation, besides if Plasma bulbs are that "efficient" then we should've seen them being used on DSLR Speedlites, but all we've seen were their applications on industrial or outdoor lightings as replacement for HIDs or Halogens. now if these Plasma bulbs are really feasible for use on a smartphone then I ask everyone to show me a any proof as It would really help "uninformed" people like me to cast our doubts off.
Posted: 2013-05-02 00:00:29
huiyi Posts: 226
On 2013-05-01 17:52:34, geniusming wrote:
I found a source that said Sony never make a 1/1.6" sensor
it suspect that the One Sony sensor will not be 1/1.6"
it shows the all sensor made by Sony here:
http://www.sony.net/Products/SC-HP/datasheet/01/index.html
all Exmor RS sensor :
http://www.sony.net/SonyInfo/News/Press/201208/12-107E/index.html
source: http://disp.cc/b/332-5C1P
Seems can't find 1/1.6...
Will Sony make a new sensor for One Sony?
IMX200。。This model has not yet announced
Posted: 2013-05-02 01:02:37
rickrz Posts: 61
On 2013-05-01 17:43:04, unknownC151A wrote:
On 2013-05-01 17:30:45, jianlin wrote:
but ur ion s3 processor is aging...in 2015...s4 gpu is ok to handle heavy games...but adreno 220 is suffering...
Heavy games like what? X-Plane 9, Temple Run 2 and Real Racing (all considered GPU intensive) runs too smooth already. I swear. Remember, you are not doing AutoCad in your phone.
Having that in mind. Would the S800 be enough to make some little autocad stuff?
Posted: 2013-05-02 01:21:50
itsjustJOH Posts: > 500
Maia said there would be another phone with a 3000 mAh battery, as well as better specs than what DACHA revealed although the 2.3 GHz S800 is unlikely. Ramu on the other hand is firm about the 3000 mAh, saying all that he has shared is XR5.
Never doubt the Huiyi.
@huiyi, how many MP?
Posted: 2013-05-02 03:09:57
jianlin Posts: 489
the dacha leak 2ghz is ideal clock for s800...300mhz less from full clock...sony s4 pro also 1.5ghz...200mhz less from full clock...
Posted: 2013-05-02 03:20:15
