Non mobile discussion
> Apple Mac Help & Chat thread
only 2 things in there jools..
stuffit something or other and an MP3 tag edit...
I'll play it by ear and see how it goes....
Posted: 2007-07-10 23:43:20
Anyone here experiencing high temperatures with a macbook pro..I am thinking of opening mine up and sorting the thermal grease. The temperature gauge is showing in the region of 65 on idle and 80 degrees when running cpu intensive apps.
I have a 2.16 core duo with 2Gb ram any of the gurus tried this yet?
Posted: 2007-07-12 22:39:05
DickySnapples Posts: > 500
there is an app you can get to increase/ decrease fan speed.
smcFanControl
might help, havent tried it personally though
N95,E70, 2x HTC TYTN,Blackberry Pearl, W880,K810,K800,N93,N93i,E65,N73
[ This Message was edited by: Dicky Snapples on 2007-07-12 23:35 ]
Posted: 2007-07-13 00:34:14
have you opened it up before?
the thermal greese thing turned out to be bogus, most people when they dismantled discovered that they acidently removed a sensor wire... meaning the sensor never knew it was running hot there fore the fans never went
if your mbp is under warrenty id send it to apple if I were you....
if not id run a hardware test and see if any faults are found
sometimes the most unlikly application can cause the graphix card or hard disc to run meaning the MBP uses the fans to keep it all cooler. Even some internet pages you may open in safari can cause this I have found.
My mbp is running at about 50 degrees and im not running much but I am in a warmer climate and I have the 2.33ghz model
Posted: 2007-07-13 00:46:39
how do you check the temperature?
Posted: 2007-07-13 00:49:49
I use a widget called istat pro
Posted: 2007-07-13 00:59:23
Interesting I am going to try and run a hardware test later, I currently use SMCFAN CONTROL to cool it down but really not making a difference, I see that it drops by about 5 degrees sometimes but from 80 to 75 is still damn hot. Its been idle and its currently running at 61.
Though the thermal greece thing has sometimes proved bogus it has also proved true...sadly my warrently just ran out and I didnt get apple care..and really cant do without my mac its my life source at the moment.
That reminds me I best be backing up tonight...justtt incase.....
Posted: 2007-07-13 03:17:00
I have the faster model too. 60 is average and fans go off all the time.
Apple says it's normal, which is sad because it's too damn hot.
Posted: 2007-07-13 03:21:52
60 on idle is crazy man, I am certain its got hotter in the last couple of months...
Posted: 2007-07-13 04:35:05
ahhh...
M4V files..
how the flock do I convert them to a format I can use outside of itunes??
also... how do I ermm remove the protection on stuff i download from itunes??
*is being a lil devilish tonight*
"live fast, die young"
take the esato daily quiz![ This Message was edited by: fatreg on 2007-07-14 00:18 ]
Posted: 2007-07-14 00:56:18
