Manufacturer Discussion >
Nokia
> Nokia E-series forum
Nokia should sell btw £200 and £300..
they would sell more of there website ! thats al im saying
Networks get you trapped into 18mth contracts due to this pricey issueits been discussed here alot! the more the handset the more months you have to pay or line rental!
Posted: 2008-03-12 23:07:18
DickySnapples Posts: > 500
im still waiting on my E90 back from Nokia.
they were really helpful first time round, swapped it out no questions asked, i had it back after a week. unfortunately the one i got back had a faulty internal screen. now, over two weeks later, no sign of my phone
[ This Message was edited by: Dicky Snapples on 2008-03-13 00:55 ]
Posted: 2008-03-12 23:23:43
i lookoed everywhere in settings miss couldnt find anything about font size
Posted: 2008-03-12 23:40:57
Hi gabbyevs
If you go to settings, then General, then personalisation, then display second one down should be Font Size.
@Dicky
Well that's not good especially as it only looked like the connection to the screen was loose, anyway you can speak to them to find out what's taking so long. Kick up a fuss who knows you may get new replacement if you complain enough.
Marc
Nokia E90,8GB SDHC, Fring, Tom Tom 6
Dogmanns Nokia E90 Blog @
http://dogmann.vox.com/
Honoured to have won BEST DEBATER
[ This Message was edited by: Dogmann on 2008-03-13 00:46 ]
Posted: 2008-03-13 01:44:40
i emailed them the other day, they said " we have escalated your concerns to the relevant department for their further review."
that was a couple of days ago now
Posted: 2008-03-13 01:59:56
Dicky, give them a ring,
it shouldn't take them that long to sort that, I mean the Nokia service centre where I normally go to takes no more then 48hrs to fix handsets!
Gabby, do as Marc suggests I really don't wanna touch the E65 to make sure im making sense lol
Posted: 2008-03-13 02:24:12
there isnt a personalition setting in general
Posted: 2008-03-13 12:26:39
@gabbyevs
OK well i don't have an E65 so was just saying what it is called on my device as just thought it would be the same as I'm sure it is on the N95 i had as well. Try going to settings and it should be under display options the same place as you alter the Light sensor, Power Saver time out and all those settings. I am assuming it has the option as Kerry said she changed hers i have my font size set to large as having such a large internal screen space is not an issue.
Marc
[ This Message was edited by: Dogmann on 2008-03-13 13:41 ]
Posted: 2008-03-13 14:41:10
yeah they must be slightly different layouts
i cant seem to find it under display either
never mind
Posted: 2008-03-13 14:45:58
Perhaps some of the options are different your phones a Sim Free model whilst mine is a Vodafone branded handset lol
if your having probs with the themes being to dark and not being able to see the text, you may have to stick with the ones that you can see
or, you could contact Nokia on there website and see if text colour ios supported for it
I really can't be bothered getting out my E65 Gabby it's on fleBay ready for sale on Sunday
use the voice aid function for reading out texts btw
Posted: 2008-03-13 16:42:25
