Sony Ericsson / Sony : Symbian phones : New P990i firmware Organiser R5A17 10/04/2007
Symbian phones
Hi Folks,
I just update my to R5A17 and I am using the SE PC Suite for Smartphones, version: 1.3.11
My problem is that the m-Router could get the connection but not the PC Suite. The above situation happened when I connected the phone and choose the "Phone mode" and not able to Sync!
On the other hand, when I connected the phone and choose the "File transfer" mode, the PC Suite reconginzed it and gave me the orange color conncetion bar and able to do file transfer.
I tried re-start the pc and the phone and still doesn't work. Can anybody help to solve the Sync problem?
My phone details:
Phone: CXC162058 R9F011
Bluetooth: CXC162058 R5A01
Org:CXC162092 R5A17
CDA: CDA162007/8 R5A16
Thanks in advance!
Posted: 2007-06-08 04:21:29
I had just the same problem. I deinstalled PC Suite, installed again and connected the phone, but I switched it off and on before and the problem was solved. I hope this will help.
Posted: 2007-06-08 07:13:39
i never have problems with reflashing my p990. i dont use pc suite. i only instal symbian drivers then seus and thats all.
i recomend update like this
) sorry for my english
Posted: 2007-06-08 10:12:19
me too!
Posted: 2007-06-08 23:06:01
sorry for the stupid question, wht is seus and how to sync with it?
fanks again!
Posted: 2007-06-09 03:44:51
@jungleboy
S.E.U.S- SonyEricsson Update Service, ie the application you use to update your phone firmware
[ This Message was edited by: mode on 2007-06-09 03:08 ]
Posted: 2007-06-09 04:04:17
can smb plz remind me how to remove software install popup ?
Posted: 2007-06-10 15:20:00
Are you talking about the sw install requests that originate from the mem stick? If so, then you have to delete all the jar/jad files on your memory stick. That should work.
Posted: 2007-06-11 11:53:19
Hello guys...anyone with World Generic 1 firmware tried to update today???
Posted: 2007-06-11 13:32:21
Maratonmannen Posts: > 500
I have WG 1, but havenīt tried yet. Waiting for someone else to try.
Posted: 2007-06-11 13:35:13
