Software, Firmware and Drivers
> K850 Firmware Overview
On 2007-12-10 16:25:49, Sebby wrote:
@vortigern
Flashing 037 with SEUS won't fix it. It needs to be flashed at a service centre.
Eh. And whats the difference? Its the same software. Do you think they change chips or something?
Posted: 2007-12-10 16:31:44
It's 10 Dec. No new firmware?
Posted: 2007-12-10 16:32:59
@bespatter, yes. The way that service centres flash the firmware is different to the way SEUS does and that makes the difference.
its already been mentioned in this thread that using SEUS will not cure the problem
a temporary measure is to master reset but the problem will likely return
that, I think, sums up whats in this thread about that problem
@dave_vl, as always, if there was a new firmware you would be reading about it already and there would be no need to ask
Unless I'm very much mistaken...
reviews:
i-mate V800 K700[ This Message was edited by: masseur on 2007-12-10 15:37 ]
Posted: 2007-12-10 16:37:30
ive got my phone updated with R1CA037 at a repair shop.. Now i just got on SEUS to see if a new one got out, and it found a update! Anyone knows about what it does..?
Edit: Hmm.. Its still the R1CA037.. weird.. But the menu feels alot smoother now than before!
[ This Message was edited by: Lillebror on 2007-12-10 15:49 ]
Posted: 2007-12-10 16:43:39
CENTRAL-EUROPE - 037 .
Posted: 2007-12-10 16:56:36
Slightly annoyed that the update hasn't materialised.
I find it ridiculous that SE have released a phone that doesn't work properly. I've had the K700, K750 & K800 and never had one single problem with any of them. How can they make the camera so that the flash doesn't go off at the right time?!!
I've currently got f/w 037 on my phone. Was the camera flash problem in place on f/w 029?
Posted: 2007-12-10 17:08:03
@1889
I suggest you have a read through this thread; it's all in here.
Posted: 2007-12-10 17:25:30
My 037 doesn't have the flash sync problem
Posted: 2007-12-10 18:06:26
Another possible bug, not sure if it's firmware specific though.... quite a few times when I try to unlock the phone by pressing the * key first, the keypad stays illuminated but the screen doesn't turn on. There is no way from then to use the phone without having to turn it off and back on, or even worse, pull the battery.
Posted: 2007-12-10 18:09:41
Sometimes mine doesnt illuminate at all, untill i press the unlock key
Posted: 2007-12-10 18:11:40
