Regional : Asia Pacific : All about Opera Mini (all version) and PH network settings
< Esato Forum Index > Regional > Asia Pacific > All about Opera Mini (all version) and PH network settings Bookmark topic
Page <  123 ... 798081 ... 192219231924>
airany12345 Posts: 1
,sir aqua wat settings ng server ng om 3.XX?, ayaw kc gumana ng an0ng0ogle eh.,at wat aces p0int gGmtn? D q xa mgmt eh,panay testing lng, tnx
[ This Message was edited by: airany12345 on 2009-05-25 17:33 ]
Posted: 2009-05-25 18:26:37
meckam Posts: 88
@master aqua
Running na.. May kulang lng pala sa custom server.. Wala .ph. Hehehe bilis nang binigay mu.
Posted: 2009-05-25 18:42:34
aquared29 Posts: > 500
@meckam
nyahahaha kala mo nsa states ka ha nakalimutan mo ph
@airany
gamit ka na lang L3 ip proxy sa inet setting mo
myGlobeInet
APN http.globe.com.ph
IP 148.233.159.58 Port:8080
SmartInternet
Access Point Name internet
operamini server
smart http://wap.smart.com.ph@195.189.142.68:80
shadow to connect http://wap.smart.com.ph
globe http://3g.myglobe.com.ph@server.operamini.net:80
shadow to connect http://www.globe.com.ph/globe.asp
me update pala sa 1st page
[ This Message was edited by: aquared29 on 2009-05-25 18:15 ]
Posted: 2009-05-25 18:51:17
,ei sir aqua d po ngana eh,gnwa q nMn mga bngy nyo setngs,,pero la p rn,,bt po kaya gnun?
Posted: 2009-05-25 19:39:00
ekaye Posts: 1
try nyo this
a shadow connect --> http://www.globe.com.ph/globe.asp
PUT a check sa ---> check time-out
TIME[s] ---> 120
Check ---> Shadow Connect
UNCHECK---> Additional
Server ---> 203.177.42.214
Port --->8080
Opera Mini Server ---> wap.amob.com@80.232.117.10:80
this is kinda old, but it works for me ^_^
kung msart ka palitan mo lang ung server and Shadow Connect
instead of these
server ---> wap.amob.com@80.232.117.10:80
gawin mong gn2
server ----> wap.smart.com.ph@80.232.117.10:80
Shadow Connect ---> http://uzzap.com
try mo lang, wla nmn mwawala sau
Posted: 2009-05-26 02:51:53
aiks, ayaw pa rn? wat b phone mo? itong om3.12 nalang b ang d nagana sau? anu b exact error message ang lumalabas
Posted: 2009-05-26 12:12:25
goarthur77 Posts: 47
@ aqua parang nagluko itong thread mo kanina. 2x ako nagpost wala lumabas.
[ This Message was edited by: goarthur77 on 2009-05-26 15:32 ]
Posted: 2009-05-26 16:26:03
Sir aqua 6600 Po cp q, ung eror eh "error in HTML"
Posted: 2009-05-26 17:15:00
@ air, ano network mo? I sent you a pm, kanina. Don't forget to save the settings.
Posted: 2009-05-26 17:21:29
Huzkyzel Posts: 99
Bro aqua, nga pla mzta po kyo dto mga adik s opera hehehe. Ahm gsto q lng snang huminge ng iba png server for my multi op opera 4.2 as of n0w i use flyproy and smart. My iba ka pbng server po? Ahm my mga m0ded dn po aq. Like SPABOK,ROCKERZ28 and THORMENTOR. hnge pa po sna aq ng iba pang server for opera 4.2 MULTI OP .TNX kip safe!!
Posted: 2009-05-27 14:58:00
