Android
> X10 mini / X10 mini pro Official Thread
On 2010-08-08 19:34:36, Bonovox wrote:
Love the gold cover
Time to buy a new one in September ?
[ This Message was edited by: Arne Anka on 2010-08-08 19:23 ]
Posted: 2010-08-08 20:19:03
I have a question, ive read again the review from gsmarena about x10 mini,accdng to that review,mini doesnt support flash to play videos directly from youtube application,is that true?or it is because mini is under Android 1.6?Samsung Spica has no flash support for the web browser but it supports flash for youtube since spica is running on Android 2.1
Posted: 2010-08-09 00:52:50
It doesn't support flash in the browser, but you can watch youtube videos trough app.
Posted: 2010-08-09 01:22:25
do you mean tru preinstalled Youtube app on x10 mini?thanks
Posted: 2010-08-09 03:05:33
On 2010-08-06 20:21:13, sampleit wrote:
talking about the market, half the available apps apparently on the market you search for them and they come up unavailable?? strange as the same ones are available on my m8's X10 for example paper toss.
im in uk by the way!
Screen resolution is a big factor when it comes to applications that's available for your device.
Posted: 2010-08-09 03:22:59
Yes, that's what he mean.
Posted: 2010-08-09 11:44:44
The answer to flash sites is Skyfire 2.0 beta(market).Hope it works with 1.6 it does with 2.1(spica)
Posted: 2010-08-09 12:49:08
can some one point me in the right direction for how to do voice dialing on the xperia x10 mini?
thanks
Posted: 2010-08-09 23:27:24
Sorry, but to my best knowledge Android 1.6 does not support voice dailing. Not sure if the fortcomming update to 2.1 supports it.
Posted: 2010-08-10 00:22:00
@Arne, OOTB the X10 Mini doesn't support Voice dialing or Voice Search... but I have all the voice features enabled on my X10 Mini Pro.
Are there programs on 2.1/2.2 that can do voice dialing WITHOUT a data connection? Old school style of pre-recording your own command?
@Wakee, I was never impressed with voice dialing (on older phones) since speed dialing was always faster and more accurate. (Since you still have to press a key to initiate, might as well press and hold the number of the person you wanna call)
On Android, Voice Dialing, is about 90% accurate. And doesn't work so well when there's background noise, like being in a car... and it requires a stable data connection. Any slight drop-out of HSPA signal during the transmission of the command will give a "Network Error...retry?" and totally eliminates the safety and convenience of it.
I would personally recommend a gesture dialer instead (just search for it in the market)
Or some phonebook apps can put direct shortcuts on your homepage to dial certain contacts.
Posted: 2010-08-10 04:41:56
