Sony Ericsson / Sony : Software, Firmware and Drivers : C905 Cybershot Xperience v 7.5
you would imagine the same files would work on all c905's
Posted: 2010-08-17 00:45:31
here is another HDR shot i just took.. what I do not like about this elf is that you still need a tripod or be able to set the phone down on something.
the process of taking the pictures is very slow, and not fast like BestPic mode.
Posted: 2010-08-17 02:09:50
jake
how many photos do you put in the elf to take?
i set the number in 7,did you left it default?,and wich program did you use to put all the shot in one??? thats the only step i have to make,cause the elf just take the pictures.
Posted: 2010-08-17 02:57:40
i am using Witchking's recommended settings.. 5 pictures
i use photomatix to make the HDR image
Posted: 2010-08-17 03:36:51
Jake,sorry for borrowing your pics
Posted: 2010-08-17 07:31:18
what did you use?
Posted: 2010-08-17 10:03:36
On 2010-08-16 23:48:28, jake20 wrote:
Elf's are a pain.. i wish i could help you guys out more.. but I had a friend basically set it up for me on my phone.. so I did not not do all the required patching myself so I am not an expert to teach someone else yet, as I am still learning as well.
once you get your boot files patched, and required library files copied over to your phone, all you need to do is run the elf on the phone, and it works.. its as simple as that.
there are lots of tutorials out there,
Witchking, and other users also post their latest working versions of the required files here
http://forums.se-nse.net/topic/49827-a2-elfpack/page__st__2700__p__706787entry706787
Help me pls, i can't download it from this site because im getting wrong to the link...
can someone up it from outside..?
ty^^
Posted: 2010-08-17 13:33:14
It seems the elf was temporarily removed, well here it is
http://www.enterupload.com/lo0tdh9da4lx/SeSn_c905test.zip.html
Posted: 2010-08-17 14:27:14
Someone requested all in one pack
Well it's simple:
Here's Elfpack arranged properly in directories:
http://forums.se-nse.net/topi[....]age__view__findpost__p__706787
But it has a bug, replace the DLL and Dyn_Const file in the archive with this one:
http://forums.se-nse.net/topi[....]age__view__findpost__p__721846
Then download the elf and run it.
Posted: 2010-08-17 14:51:15
ty witchking ^^
i have just to up it or patchers?
Posted: 2010-08-17 14:52:31
