General discussions : Rumours : Sony Xperia Rumours 2017
Esato Forum Index > General discussions > Rumours > Sony Xperia Rumours 2017 Bookmark topic
Page <  123 ... 798081 ... 180181182>
tk007 Posts: 173
Adida 2018 lineup design are total change or minor changes ?
Posted: 2017-07-02 06:39:20
ADIDA Posts: > 500
2018 H1=Big Design Change
[ This Message was edited by: ADIDA on 2017-07-02 05:52 ]
Posted: 2017-07-02 06:52:14
LumberjackX Posts: 222
Maybe it is about the 3D face recognition.
Sony is supposed to show it at MWC Shangai.
I do not knot if the event is over or yet to begin.
Posted: 2017-07-02 07:57:50
XperiaJunkie Posts: > 500
This is old news as it was mentioned by an anonymous source months ago who told us about the XZ Premium before it was officially announced.
Posted: 2017-07-02 08:49:29
badassmam Posts: > 500
The XZ1 and XZs are near identical in terms of internal specs, XZP owners won't mind because of the 4K screen. I think the camera sensor could be slightly updated. I did see a prototype with slightly different design to the current XZ.
Regarding bezel-less displays, you have to consider the compromises of having such a design. You'd definitely lose the selfie camera which is probably the best on the market, you'd add a lot of thickness and so on. I'd rather have high quality hardware than lose it for aesthetics.
Posted: 2017-07-02 09:30:53
tonylcc Posts: 370
i would like to see thicker body, which makes bigger camera module(OIS), and bigger battery, i wouldnt really mind my phone as thick as X Compact(9.5mm)
Posted: 2017-07-02 09:34:32
Archdragoon Posts: > 500
Well if it's thick for something great then of course user would be happy.
What do you guy think about thicker camera module for optical zoom then ?
Posted: 2017-07-02 10:57:54
RacSony Posts: > 500
"near identical in terms of internal specs" means XZ1 will have S820 instead of S835? I hope not....
" I did see a prototype with slightly different design to the current XZ"
Would you mind sharing how different?
Posted: 2017-07-02 13:41:39
I guess he wanted to say XZ1 is equal to XZP from inside, not XZs . Except the 4K, it might be better.
Or maybe even SD836.
For 2018, I hope the 100% screen does not turn out to be real.
It would look ugly, hard to handle. Impossible to use cam without both hands.
For me screen/body = 77% is the perfect size.
Also 16:9 screen.
XZ1 can be my last high end phone depending on how it looks.
I'd give up on front speakers and stereo to have 16:9 screen.
If XZ1 is 18:9, I' ll wait XA2.
Helio P30 may be similar to SD660.
[ This Message was edited by: LumberjackX on 2017-07-02 16:19 ]
Posted: 2017-07-02 14:24:58
My bad for not being clear, lets say XZ1 is like XZP without the 4K screen. I can't talk about prototypes in detail but lots of designs are being tested with some moving ahead and others not. An XZ Ultra that matches the specs of the XZP would look the same but just larger in footprint so imagine how unwieldy that would be, that's why the XA1 Ultra exists because there have to be some compromises.
[ This Message was edited by: badassmam on 2017-07-02 19:36 ]
Posted: 2017-07-02 20:35:56
