Sony Ericsson / Sony : Software, Firmware and Drivers : fMA f[??] Mobile Agent, software for sms and phone monitoring
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > fMA f[??] Mobile Agent, software for sms and phone monitoring Bookmark topic
Page <  123 ... 798081 ... 106107108>
Zyron Posts: 1
Hi!
I just love fma, it rocks!
But i have a few questions:
Is it possible to use the native bluetooth,
i.e. not the serial connection?
how do I uninstall media control?
and how come I can't write messages with more than
60 chars when using the norwegian language
chars like ø æ å Ø Æ Å?
Thanks!
Posted: 2003-10-25 22:52:03
antaean3000 Posts: 7
how do i get it on to my phone? i dont have cables for my pc.can it be downloaded by wap/gprs some how?
Posted: 2003-10-26 20:13:09
FluxXx Posts: 3
On 2003-10-24 02:04:41, GOwin wrote:
You can do the same by enabling password protection when the screensave is activated.
Yeah, but when you get back, it would be cool if the computer unlocked itself if the bluetooth got connected again to the same phone
Posted: 2003-10-27 16:19:20
kreatiV Posts: 40
0.10 RC1 is released...
The Problems with Norwegian / German Language is now solved and alot more!
Notes:
We are proud to announce Release Candidat 1 of FMA
version 0.10. It's a pre-release build but it contains a lot
of new features and you'll be just amazed. Improved
stability, good performance, increased functionality and
shiny new look. Whatmore do you like? Grab and enjoy
for free!
The Fma Team
Changes:
- Added Groups folder in phone explorer.
- Added Add/Delete contact to/from Group.
- Added Obex Folder browser service support.
- Added support for phone folders browsing.
- Added support for more Obex headers.
- Added contact phone numbers sanity check.
- Added download from phone support for pictures,
sounds and themes (everything browseable).
- Fixed Proper detection if the phone is missing
or out of range on connect.
- Fixed AV errors on exit (ThemeMgr).
- Fixed Multi-part Obex operations are now canceled
properly.
- Fixed Changing profile when disconnected issue.
- Contact fileds max length is retrieved from phone
if Obex is supported.
- Obex Luid max length is retrieved from phone.
- Changed Obex version update to $10.
- Show selected SIM operator on connect.
- Show progress on Obex get operation (optional).
- Messaage details compacted GUI.
- Select Contact compacted GUI.
- Made Activity log optional.
- Make Explorer optional.
- Added clock synchronization with PC clock.
- Added percents to battery and signal statuses.
- Added option to disable strict UCS-2 check, in
order to enable German special chars usage.
- Added battery estimated time left indicator,
showing the d:hh:mm in phone info page.
- Reuse progress dialog in several operations.
- All changes since version 0.0.9.13 including the
patches 13a, 13b, 13c and 13d.
- Bug-fixes.
Posted: 2003-10-27 19:14:55
ramonccc Posts: 15
I just downloaded the 0.10.RC1 and I cannot connect anymore. I am using a t68, MS bluetooth, and Windows XP. I was using 13a without any problem. I tried both bluetooth and infrared and nothing is working.
The log for bluetooth is the following:
09:26:06 Connecting via Bluetooth
09:26:08 Turn off phone Echo
09:26:08 Clear previous settings
09:26:08 Identify phone model
09:26:08 Try switching character set to UTF-8 or Latin-1
09:26:09 Check for special voice dialing commands (t68)
09:26:09 Check SIM status
09:26:10 Request calling line ident
09:26:10 Request Alpha Tags
09:26:10 Enable Call Monitoring
09:26:10 Enable New Msg Notification
09:26:11 Enable Music Mute Notification
09:26:11 Checking EOBEX Capability
09:26:11 Obex is OK
09:26:11 Obex Build contact structure
09:26:11 Obex Session Established
09:26:11 Obex Negotiateing...
09:26:12 Obex Negotiated: Packet Size = 512
09:26:13 Retrieving telecom/pb/info.log
09:26:13 Packet Sucessfull. Get=441
09:26:13 Obex Session Ended
09:26:13 Contact: Set max items = 458
09:26:13 Contact: Set name length = 30
09:26:13 Contact: Set e-mail length = 50
09:26:13 Contact: Set title length = 15
09:26:13 Contact: Set organization length = 15
09:26:13 Contact: Set phone length = 40
09:26:13 Contact: Set LUID length = 12
09:26:13 Flushing possible stray "OK"...
09:26:14 Got the stray "OK" when flushing
09:26:14 Obex Build phone folders
09:26:14 Obex Session Established
09:26:14 Obex Negotiateing...
09:26:15 Obex Negotiated: Packet Size = 512
09:26:15 Obex Negotiated: Application = Folder Browsing
09:26:16 Obex Session Ended
09:26:16 Flushing possible stray "OK"...
09:26:16 Got the stray "OK" when flushing
09:26:16 Disconnecting...
09:26:16 Working Offline
09:26:16 OnDisconnected called
09:26:16 Phone disconnected or out of range.
09:26:16 Connection Error
Ramon
Posted: 2003-10-28 09:28:42
almanganeez Posts: 1
Hi Ramon..
I'm having the same problem. However, I have a T68i and i'm connecting to Windows 2000 Professional via Infrared! Here's my log:
14:11:14 Connecting via IRDA
14:11:16 Disconnecting...
14:11:16 Working Offline
14:11:16 Phone disconnected or out of range.
14:11:16 Turn off phone Echo
14:11:19 Clear previous settings
14:11:19 Identify phone model
14:11:19 Try switching character set to UTF-8 or Latin-1
14:11:20 Check for special voice dialing commands (t68)
14:11:20 Check SIM status
14:11:22 Request calling line ident
14:11:22 Request Alpha Tags
14:11:22 Enable Call Monitoring
14:11:23 Enable New Msg Notification
14:11:24 Enable Music Mute Notification
14:11:24 Checking EOBEX Capability
14:11:24 Obex is OK
14:11:24 Obex Build contact structure
14:11:24 Obex Session Established
14:11:24 Obex Negotiateing...
14:11:25 Obex Negotiated: Packet Size = 512
14:11:26 Retrieving telecom/pb/info.log
14:11:26 Packet Sucessfull. Get=441
14:11:26 Obex Session Ended
14:11:26 Contact: Set max items = 439
14:11:26 Contact: Set name length = 30
14:11:26 Contact: Set e-mail length = 50
14:11:26 Contact: Set title length = 15
14:11:26 Contact: Set organization length = 15
14:11:26 Contact: Set phone length = 40
14:11:26 Contact: Set LUID length = 12
14:11:26 Flushing possible stray "OK"...
14:11:27 Got timeout flushing OK (no stray "OK")
14:11:27 Obex Build phone folders
14:11:27 Obex Session Established
14:11:27 Obex Negotiateing...
14:11:28 Obex Negotiated: Packet Size = 512
14:11:28 Obex Negotiated: Application = Folder Browsing
14:11:29 Obex Session Ended
14:11:29 Flushing possible stray "OK"...
14:11:29 Got the stray "OK" when flushing
14:11:29 Disconnecting...
14:11:29 Working Offline
14:11:29 Phone disconnected or out of range.
14:11:29 Connection Error
Posted: 2003-10-28 11:12:13
Pipsik Posts: 1
The same situation here :
11:43:54 Connecting via Serial
11:43:55 Discard received garbadge.
11:43:55 Turn off phone Echo
11:43:55 Clear previous settings
11:43:55 Identify phone model
11:43:56 Try switching character set to UTF-8 or Latin-1
11:43:56 Check for special voice dialing commands (t68)
11:43:56 Check SIM status
11:43:57 Request calling line ident
11:43:57 Request Alpha Tags
11:43:58 Enable Call Monitoring
11:43:58 Enable New Msg Notification
11:43:58 Enable Music Mute Notification
11:43:59 Checking EOBEX Capability
11:43:59 Obex is OK
11:43:59 Obex Build contact structure
11:43:59 Obex Session Established
11:43:59 Obex Negotiateing...
11:44:00 Obex Negotiated: Packet Size = 512
11:44:01 Retrieving telecom/pb/info.log
11:44:01 Packet Sucessfull. Get=441
11:44:01 Obex Session Ended
11:44:01 Contact: Set max items = 504
11:44:01 Contact: Set name length = 30
11:44:01 Contact: Set e-mail length = 50
11:44:01 Contact: Set title length = 15
11:44:01 Contact: Set organization length = 15
11:44:01 Contact: Set phone length = 40
11:44:01 Contact: Set LUID length = 12
11:44:01 Flushing possible stray "OK"...
11:44:01 Got the stray "OK" when flushing
11:44:01 Obex Build phone folders
11:44:01 Obex Session Established
11:44:01 Obex Negotiateing...
11:44:02 Obex Negotiated: Packet Size = 512
11:44:02 Obex Negotiated: Application = Folder Browsing
11:44:03 Obex Session Ended
11:44:03 Flushing possible stray "OK"...
11:44:03 Got the stray "OK" when flushing
11:44:03 Phone disconnected or out of range.
11:44:03 Connection Error
I am using T68I and MSI bluetooth.
on BT connection i am recieving a "11:50:25 Connecting via Bluetooth
11:50:25 Error 10047 in function Connect (socket)
Address family not supported by protocol family" message
connection via BT serial was working on my last fma version which was 0.0.9.9
what's wrong guys ?
PS: i guess that is the something with fma 0.1.0.19 because my other BT serial or BT software works fine, the old version of fma still works fine too
C U
[ This Message was edited by: Pipsik on 2003-10-28 10:56 ]
Posted: 2003-10-28 11:49:01
icecoolsam Posts: 39
I am also facing the same problem while connecting using fma 0.1.0.19 using IrDA, here;s the log
20:37:57 Phone disconnected or out of range.
20:37:57 Turn off phone Echo
20:37:57 Clear previous settings
20:37:58 Identify phone model
20:37:58 Try switching character set to UTF-8 or Latin-1
20:37:59 Check for special voice dialing commands (t68)
20:37:59 Check SIM status
20:38:01 Request calling line ident
20:38:01 Request Alpha Tags
20:38:01 Enable Call Monitoring
20:38:01 Enable New Msg Notification
20:38:02 Enable Music Mute Notification
20:38:02 Checking EOBEX Capability
20:38:02 Obex is OK
20:38:02 Obex Build contact structure
20:38:03 Obex Session Established
20:38:03 Obex Negotiateing...
20:38:04 Obex Negotiated: Packet Size = 512
20:38:05 Retrieving telecom/pb/info.log
20:38:05 Packet Sucessfull. Get=442
20:38:05 Obex Session Ended
20:38:05 Contact: Set max items = 485
20:38:05 Contact: Set name length = 30
20:38:05 Contact: Set e-mail length = 50
20:38:05 Contact: Set title length = 15
20:38:05 Contact: Set organization length = 15
20:38:05 Contact: Set phone length = 40
20:38:05 Contact: Set LUID length = 12
20:38:05 Flushing possible stray "OK"...
20:38:05 Got the stray "OK" when flushing
20:38:05 Obex Build phone folders
20:38:05 Obex Session Established
20:38:05 Obex Negotiateing...
20:38:06 Obex Negotiated: Packet Size = 512
20:38:06 Obex Negotiated: Application = Folder Browsing
20:38:06 Obex Negotiated: Connection# = 17
20:38:07 Obex Session Ended
20:38:07 Flushing possible stray "OK"...
20:38:07 Got the stray "OK" when flushing
20:38:07 Disconnecting...
20:38:07 Working Offline
20:38:07 Phone disconnected or out of range.
20:38:07 Connection Error
Posted: 2003-10-28 16:23:45
jiggs Posts: 8
Hi,
Am having problem on sending SMS using bluetooth and infrared. It displayed a dialog box 'Command return error.' At the bottom, it displayed 'Exception: ERROR'. SMS handling works fine before but starting version 0.0.13, I got this error.
I have W2K, billionton bluetooth, T610 phone.
Thanks.
Jiggs
Posted: 2003-10-30 07:01:00
kreatiV Posts: 40
RC2 has been released!
- Fixed phone clock automatic sync.
- Added Obex connection in use dialog.
- Message properties has only Close button.
- Headset button added for incomming calls
to answer and disconnect (by request).
- Missed calls is now retrieved from phone
and can work in offline mode too.
- Added Voice call and Send message commands
from Missed calls window.
- Fma logo used in several places.
- Proximity detection preparations.
- Includes all patches 19a, 19b, 19c, 19d.
- Bug-fixes.
PROXIMITY DETECTION looks really nice, can't wait for it to work
Posted: 2003-10-31 20:31:02
