10 mm going up to 14-15 at the sensor is likely for the Xperia i1 Honami. I wonder if they will take Nokia's approach of putting the sensor on top of the phone, ala N8/808, thus making the phone top heavy, or go their own way and maybe put it towards the middle.. kind of like the Satio..
It took a while for Sony(Ericsson) to get a grip of android's imaging stack and jpeg processing, but it seems like they are finally there.
Either way, this is really good news for photography lovers.. and I am really hoping its water proof..
This technology will go head to head with the Nokia EOS .. which if rumors are true, should be better than the 808.
[ This Message was edited by: cu015170 on 2013-05-08 16:08 ]
Posted: 2013-05-08 17:07:48
I have high hopes regarding it. It would be really nice if they provide us with bigger pixels than we already got in current and past cameraphones. 2 micron pixels would be very nice indeed.
Let's hope that the lenses used won't kill the sensor resolution like in all SE or Sony past cameraphones.
I have a Nokia 808 PureView and all I can say is that a great part of its success is down to its lenses. What a wonderful resolved resolution they have! The N8 suffered from intensive flare, but the 808 is quite impressive when it comes to optical quality.
People tend to look at the sensor size only, even DSLR starters. The truth is that a bad lens can really bottleneck a great sensor.
[ This Message was edited by: Vit on 2013-05-08 16:20 ]
Posted: 2013-05-08 17:16:51
Xperia A (SO-04E/Xperia Ace)/Dogo:Size and weight: 131 mm × 59 mm × 10.5 mm, 141 gSystem: Google Android 4.2 Jelly BeanBattery: 2,300 mAhDisplay: 4.6", HD (720 x 1280)CPU: Qualcomm APQ8064, 4 x 1.5 GHzRAM and storage capacity: 2GB, 32GBColors: Black, white, mint, pinkRelease: Mid-May 2013Waterproof and dustproof
[ This Message was edited by: Detox on 2013-05-08 16:51 ]
Posted: 2013-05-08 17:30:59
Anybody knows what this C6616 is?
http://ptcrb.org/vendor/compl[....]equest_guest.cfm?modelid=23321
C6606 is the T-Mobile variant. C6616?
[ This Message was edited by: unknownC151A on 2013-05-08 16:36 ]
Posted: 2013-05-08 17:35:24
Canadian carrier variant of Xperia Z
Bell Canada
[ This Message was edited by: randomuser on 2013-05-08 16:37 ]
Posted: 2013-05-08 17:37:16
10.1 thick? I like those dimensions! This should lay very good in ones hand! Size and weight are very equal to Xperia S which has only 4.3" screen:
Xperia S:
128 x 64 x 10.6 mm
144 g
Xperia A:
131 x 59 x 10.5 mm
141 g
[ This Message was edited by: -16- on 2013-05-08 16:55 ]
Posted: 2013-05-08 17:55:14
Dont you feel its waste and unnecessary,xperia Z mini mighte be called with fatass
Hope Honami rumour might be true 8mm slim with rumoured spec
best design ever from Sony
Posted: 2013-05-08 17:59:15
Size 131 mm × 59 mm × 10.5 mm
I must laugh about the dimensions...
And btw, release mid-may??? So next week?!
[ This Message was edited by: king-james on 2013-05-08 17:08 ]
Posted: 2013-05-08 18:04:14
Don't like that "yo momma" dimensions. Come on Sony, make your phones slimmer, not just your flagships.
Posted: 2013-05-08 18:08:05
I get a little doubtful when I see 59 mm, 67 mm should be more realistic...
[ This Message was edited by: Detox on 2013-05-08 17:18 ]
Posted: 2013-05-08 18:15:29
