Page <  123 ... 806807808 ... 184118421843>
DACHA Posts: > 500
On 2013-05-09 16:02:18, stook wrote:
@napahlm
Dogo (131x67x10.5mm)
Xperia A (SO-04E) ‘Dogo’ is 139mm (H) 71mm (W)× 7.9mm
5" display as listed in the manual
https://docs.google.com/file/d/0BzLnP-NEhcXlSy03Q3A1dEUtbVk/edit
Posted: 2013-05-09 16:07:22
stook Posts: 76
ok, then Sweden gets C5503 with the above Dogo mesaures
Posted: 2013-05-09 16:09:10
MartenR Posts: 313
I guess Xpreia A is Xperia ZL for the Japanese market. Considering they don't have ZL right now, releasing a cheaper version of Z totally makes sense. Also remember that the Japanese Z has some extra features compared to the international ones.
Posted: 2013-05-09 16:15:06
Ambivalent_ Posts: > 500
Guys, some bad news up ahead regarding Honami;
so I've heard Bioniz will not be present as a an actual hardware chip but merely as a processing engine. Bioniz (chip) equipped phone only in '14.
Nevertheless, due to much better image processing picture quality should be close to 808.
Also, small hopes for Xenon since Exmor RS is primarily designed for LED flash.
[ This Message was edited by: Ambivalent_ on 2013-05-09 15:26 ]
Posted: 2013-05-09 16:25:19
AFAIK there is no such thing. And there is no software BIONZ in the first place.
What you just posted is exactly same as zomg's post back in January. So I guess you are quoting zomg
In any case, if there won't be a BIONZ chip there won't be BIONZ software as BIONZ is hardware feature and cannot be turned into software. Same reason why X-Reality PRO can never be ported to Xperia as it cannot work without dedicated hardware.
[ This Message was edited by: randomuser on 2013-05-09 15:46 ]
Posted: 2013-05-09 16:43:52
DACHA Posts: > 500
Togari is SO-05E for Docomo clocked at 1.8 Ghz and is most likely equipped with an SD 800 SoC.
Posted: 2013-05-09 16:53:23
No, I'm not referring to zomg, nor anybody's older info. I've just heard it and immediately posted it here. I'm not an insider nor do I act like one. I just occasionally receive info (from a proven source) and then forward it here.
Anyway I'm honestly hopping you're right because we'll get a better device. Although Mairamadan's specs are the ideal one.
[ This Message was edited by: Ambivalent_ on 2013-05-09 15:56 ]
Posted: 2013-05-09 16:54:53
No, you misread. It will use LTE Cat 4 1.8ghz band. It's not the CPU clock.
Posted: 2013-05-09 16:58:44
motvikt Posts: > 500
I'm afraid that probably means s600 :/
Posted: 2013-05-09 17:13:30
No. S800 is confirmed for Togari.
Posted: 2013-05-09 17:21:39
