I can't speak for -XYZ but I myself got the X10 mini as my first smartphone and I loved it! I had no smartphone habits, did not realize the potential and you didn't get nearly as much out of a large phone back then as you get now.
Today, with a 4" Xperia P I can't even imagine going back to that tiny 2.55" screen. And I'm probably getting the Togari if I'll be able to fit it in my hand and pocket. I'm probably on the phone more than on the laptop now, so carrying something larger around is more viable.
[ This Message was edited by: calim on 2013-05-16 16:46 ]
Posted: 2013-05-16 17:41:26
Same thing for me, except I had a X10 Mini Pro before and went to an S...
I just can't use anything smaller than 4.3 inch... A 5 inch on S body size (maybe a bit bigger is also okay) would be perfect...
Posted: 2013-05-16 20:43:02
Guys, just letting you know what I heard today, Honami (i1) may end up with 4.8 inch 1080p screen.
Posted: 2013-05-16 21:25:22
http://www.xperiablog.net/201[....]ny-c6833-model-number-appears/
Posted: 2013-05-16 21:42:47
On 2013-05-16 17:21:56, sami92a wrote:
On 2013-05-16 16:40:18, -XYZ wrote:
Having owned the Ray for 20 months now, I can say that 3.3 inches at a 16:9 aspect ratio, is far, far too small for my needs. Typing is ridiculously difficult in portrait. Its a damn nice looking phone, but for me 4-inches at 16:9 is the minimum.
so why did you buy it?
Because it fulfilled my needs at the time. At the time, I needed the phone for calls/texts and emails at most. Now I surf the web all the time. My needs changed and so I need a bigger phone. I'm not saying the phone was bad, because it isn't (though mine has developed a fault in its heat-sink and overheats way too often), it merely no longer fulfills my needs.
Ooooh, that sounds absolutely excellent. As long as they can get the overall body to be similar to, or slightly smaller than the SGS3, then its definitely my next phone.
[ This Message was edited by: -XYZ on 2013-05-17 00:39 ]
Posted: 2013-05-17 01:38:03
whats the source of that rumour?
Posted: 2013-05-17 03:16:13
Probably tied to that new Sharp Aquos with 4.8" IGZO screen.
Posted: 2013-05-17 04:38:30
^That strengthens more the possibility of an IGZO screen. Hope Sony makes the bezel very minimal on this phone because if it would be thick, at least it would be shorter and narrower.
Posted: 2013-05-17 04:45:46
Nothing to do with IGZO, Sharp has 5 inch IGZO panel too. In fact 5 inch IGZO panels are more easily available than 4.8.
I don't think i1 will get 4.8 inch because its in alpha development stage and screen size doesn't change this late in development. Screen size can change only when a phone is in very early development stage, rather planning stage.
[ This Message was edited by: randomuser on 2013-05-17 04:47 ]
Posted: 2013-05-17 05:39:23
As long as the screen quality is on par with the HTC One, has a great design/build-quality, polished/clean UI and great performance, I don't care if it's 4.8' or 5'. The rest of the rumored specs for Honami up until now are smoking!
Posted: 2013-05-17 07:16:31
