Page <  123 ... 836837838 ... 184118421843>
Ambivalent_ Posts: > 500
On 2013-05-18 10:50:48, vikeviki wrote:
@ambi
what about thickness,is it fatty Z or less fatty
I would assume more thick but that's only my guess bearing in mind the battery and camera.
Posted: 2013-05-18 10:58:57
maloqs Posts: 275
I personally think that the battery life for phablet will not be much better than Z but Honami will be have splendid battery life,right?
Posted: 2013-05-18 11:03:08
nightwing369 Posts: 415
On 2013-05-18 10:38:51, Ambivalent_ wrote:
Same source as above on Honami;
Triluminous technology
S-Master MX chipset
2930mAh Battery
Xenon flash + X LED
Global release: August - September
Price same as Z
[ This Message was edited by: Ambivalent_ on 2013-05-18 09:44 ]
I thought it was going to release either right at the very end of September/right at the very beginning of October? So is what you're saying instead information which is XR4?
Posted: 2013-05-18 11:50:31
jianlin Posts: 489
S-Master MX chipset
2930mAh Battery
Xenon flash + X LED
Price same as Z
great...2930mah battery i hope with IGZO screen....more battery saving..btw Ramu source mentioned at least 3000mah battery...
Posted: 2013-05-18 13:33:46
Detox Posts: > 500
Probably 3000 mAh typical/2930 mAh minimum.
Posted: 2013-05-18 13:45:37
Yes, 2930 = 3000. Sony uses the minimum capacity in specs and not typical. 2930 is minimum/3000 typical.
Posted: 2013-05-18 14:23:32
-XYZ Posts: > 500
Really want to see what the Honami looks like. Soon hopefully.
Posted: 2013-05-18 15:01:17
vikeviki Posts: > 500
Do Honami uses flapless waterproof for audio port/All ports or it will be same as Xperia ZR?
Posted: 2013-05-18 15:19:22
Felimenta97 Posts: > 500
How does that looks like?
Posted: 2013-05-18 15:50:29
^like magic!
As far as I'm aware, I don't think there's technology available that would allow a flapless water resistance to the level of Z and ZR. They have companies that will take apart your device and coat the parts with a protective coating, but that only protects for accidental spills, submerging.. etc. and doesn't let you USE the device. you still have to let it dry before using it.
i too am excited to see what honami looks like!
Posted: 2013-05-18 15:58:47
