Xperia UL for KDDI announced.
5 inch Display FHD
Water Proof IP5/8
Ram 2gb, Rom 16gb
APQ8064[Edit: S4 Pro/thanks ramu] 1.5GHz quad core
About 135 x 71 × 10.5 mm
source[ This Message was edited by: maxtune123 on 2013-05-20 05:00 ]
Posted: 2013-05-20 04:46:01
As I said, there won't be any S600 phone from Sony.
UL too has APQ8064, unlike S600 as was being suggested
Posted: 2013-05-20 05:45:03
^Why?
Posted: 2013-05-20 05:52:09
Sony has a lot of S4 Pro stock, and for 2H they are moving to S800 for the high end. So no room for S600.
S800 -Togari, Honami, Ray 3, One Sony tablet, and a mystery phone below Honami.
Posted: 2013-05-20 06:26:53
The Xperia UL looks a lot better to me than the Xperia A. The bottom bezel is similar to that of the ZL. I like how they moved the screen down because there is a lot of unused space below the screen on the Xperia A and Z.
Posted: 2013-05-20 06:38:44
The main thing that make me excited was not the phone
but the......................
transparent buttons
[ This Message was edited by: stedus on 2013-05-20 05:56 ]
Posted: 2013-05-20 06:55:27
On 2013-05-20 04:45:26, itsjustJOH wrote:
On 2013-05-19 22:52:27, RumrCollectr wrote:
You can't combine WhiteMagic and Triluminos technology.
I don't see how it can't be combined. WhiteMagic uses a filter with RGBW sub pixels, while Triluminos tech uses QD with blue LED as backlight to produce a better white light. IGZO and WhiteMagic can't be combined, I think.
Whitemagic uses a white backlight, the extra white pixel is therefore just letting the white backlight through without a red green or blue filter. In Triluminos the backlight isn't white, it's blue, so you can't just let it through.
Posted: 2013-05-20 07:17:22
Blue LED plus two QDs that absorb some light from the blue light and convert it to red and green. Add it all and you get a white backlight. Ordinary LED backlight uses a blue LED coated with phosphor to create white light, but also produces colors near white (wider band) that the filters may not be able to filter.
Posted: 2013-05-20 07:36:12
Sort of wish we got the Xperia UL in the west as well.
Posted: 2013-05-20 07:43:38
There's no point to that. You might as well just use the red and green QDs that you already have in the R + G subpixels.
Posted: 2013-05-20 07:46:47
