On 2013-05-21 02:53:02, vivftp wrote:
I'm willing to bet thickness is areason Sony will be releasing so many s800 variants. One will be a thicker, no compromise phone (honami) and there will be athinner one that will probably have the same camera as Xperia Z.
Just my guess
Well, that would be a good option.
Posted: 2013-05-21 03:12:16
On 2013-05-20 17:46:54, MartenR wrote:
JDI is one of htc One's panel suppliers and htc One's display has 1600:1 contrast ratio but this display is just 1000:1 I think Xperia ZL even has contrast ratio above 1100:1.
XZ : Contrast ratio: 705:1 (nominal) / 2.462:1 (sunlight)
XZL : Contrast ratio: 1294:1 (nominal) / 2.352:1 (sunlight)
Got it from GSM Arena
Posted: 2013-05-21 06:00:38
On 2013-05-20 23:03:32, Felimenta97 wrote:
Well they won't be able to.
Every thing we know so far from the Xbox Infinity is beyond everything we have from PS4. Unless Sony does something, or MS screw up really hard, then Xbox already won this generation.
That's too early to say, I don't know where you get the info, but from where I read about gaming consoles, PS4 has the upper hand, since the rumored PS4 will be using an AMD x86-64 cpu which is similar architecture as a PC has, and that PS4 is very developer friendly unlike the PS3. Ubisoft even praised the PS4
A console's success relies heavily on the games that will be on it, not just it's specs.
Also, I just noticed it has a Xenon flash. I never saw one of these (I'm 16 only, though)
really? not sure if you are joking or what, but a xenon flash is the same as the ones on those digital cameras, it is nearly impossible for it to be yellowish, plus you get excellent lighting as well as blur free shots when you have xenon due to it's instantaneous light being very bright.
Anyway this has been off-topic, but still Kaz is pushing Sony in the right direction, in my opinion Sir Howard Stringer CEO of sony 2005-2012 literally brought sony to its knees, It was just terrible Sony was so slow back in those years, no groundbreaking product and it's as if Sony has no direction to where it's going, they even sold the first PS3s at a loss, it was just too expensive to manufacture back then. With Kaz I think Sony is coming back, only time will tell though.
Posted: 2013-05-21 06:17:47
I actually think Sony has upper hand in this generation console war. Rumors suggest that it has more raw power, the controller also looks awesome-you can hold Xbox controller in just one way but you can hold dual shock controller in different ways depending on what you are playing, ps4 is the first 4k setup box and finally I've read somewhere that Xbox needs to pay patent fee to Sony if they want to use blu-ray; I can't imagine next Xbox not supporting blu-ray and patent fee is pure loss for MS and pure profit for Sony. The other thing is Sony is rumored to push hard on free to play games. In India, ME and parts of Africa MS has almost 80% market share mainly because of people there are able to play Xbox games cracked and for less money.
Posted: 2013-05-21 07:32:26
XR3 Rumor
Honami uses
VA type panel, not IPS
Viewing angles are perfect - 178 degrees horizontal.
And the screen is "very impressive" according to someone who has seen it.
Posted: 2013-05-21 08:07:22
Does it mean that it's IGZO or not?
btw why did you change your avatar?
Posted: 2013-05-21 08:12:25
IGZO is also VA, so IGZO is in the run along with Sony. But Sony is ahead at the moment
JDI is ruled out completely as they don't make VA panels.
Not getting the Z, so changed avatar back to S
[ This Message was edited by: randomuser on 2013-05-21 07:15 ]
Posted: 2013-05-21 08:15:26
^Yay no JDI!
BTW, I thought you already had a Z?
Posted: 2013-05-21 08:24:39
Also, uterly dissapointed with Sony. What's the reason with Xperia UL? Also, Honami, 15 mm and still trying to make it 12mm? That means no thin phone with a good camera (don't need to be that awesome)...
Well, or Sony comes up with something different (same specs, except that nice huge camera), or I'm moving out.
Holy crap your posts are cringe worthy, worse than that mediar dude. I don't even think you should be allowed to have an opinion, your terrible at it. And stop shopping at the women's section for jeans.
Man up, we been stuck on this fad of thin phones and small sensors for too long now. 12mm would be acceptable and by no means a brick. Thats slightly bigger than my Acro and its far from "thick".
Posted: 2013-05-21 08:32:21
@XperiaPro: calm down man, you don't need to attack Feli
he's been supporting Sony for so long and even now
I guess he just disappointed about Sony's answer to those competitors, they haven't done much since the XZ came out :
However, I disagree with him about the PS4 unable to compete with the New Xbox, because those 2 console will use the same x86 architect, so the raw power will be the same (i guess
), but the Kinect add on might be the key differentiation from PS4 (who knows...)
For mobile field, they haven't done enough yet, the XZ is good, but the hype is too short......
I hope the Honami and Togari will fix these issues
[ This Message was edited by: stedus on 2013-05-21 07:39 ]
Posted: 2013-05-21 08:38:47
