Page <  123 ... 968969970 ... 184118421843>
itsjustJOH Posts: > 500
Everything that has been leaked and shared here summarized in a blog post by XperiaBlog.
Xperia Z Ultra (Togari) is a beast: 6.4-inch Triluminos display, Snapdragon 800, 6.5mm thin
Posted: 2013-06-07 17:53:53
So Togari's "Ultra" hover touch display can detect pressure? if that's true then wow!
And it seems that Sony may have realized that other companies are starting to incorporate weather sealing capabilities on their phones so they decided to up its notch with better IP rating while maintaining good aesthetics to maintain their lead.
[ This Message was edited by: razec on 2013-06-07 17:05 ]
Posted: 2013-06-07 17:58:48
unknownC151A Posts: 459
C6833 and C6802 is Honami and Togari respectively?
Posted: 2013-06-07 18:07:42
razec.. it's infrared optical touch.. so it can't sense pressure, but it can detect the size of the object.
so it can detect the size of the object obstructing the IR field, but not pressure. so if you were to use the tip of a pen and press down, it won't get bigger.. it will remain a small dot.
Posted: 2013-06-07 18:08:47
semo Posts: 182
But if you use something with a soft tip then you can measure pressure too
Posted: 2013-06-07 18:33:17
That's where the stylus might come in handy.
Posted: 2013-06-07 18:39:45
ascariss Posts: > 500
Will be interesting to see how this touch interface will work with various pens and what not, would be nice if sony provided a pen with a thin tip for writing, since I wouldn't want to use a real pen or even pencil to write on the screen even if it is scratch resistant and durable.
Posted: 2013-06-07 18:40:14
if it's a soft tip like a paint brush.. but not like a felt tip marker or anything. still not real pressure sensing.
Posted: 2013-06-07 18:42:23
Detox Posts: > 500
On 2013-06-07 17:40:03, nightwing369 wrote:
Then Honami is only just a phone and not quite a phablet.
Posted: 2013-06-07 18:45:58
motvikt Posts: > 500
I dont think they will use a neonode touch thingy. As far as I know that requires boarders around the screen where the infra-red sensors are. That would look silly on a phone
Edit. Also neonode is aimed at low-cost E-readers and stuff like that
[ This Message was edited by: motvikt on 2013-06-07 17:53 ]
Posted: 2013-06-07 18:49:18
