XperiaJunkie Posts: > 500
@ Randomuser quiet a few posts about the memory of the Togari some say it's 16GB + SD card support and others saying its 32GB but no mention of an SD card any chance you can clear this up for good hope it's the 16GB option with SD card support as 32 GB will be reduced to around 25GB will all software/bloatware like the Xperia S
Posted: 2013-06-09 12:20:43
Unknown13x cleared it a few posts back. You can trust him more than me.
16 GB it is.
Posted: 2013-06-09 12:21:58
Cheers for clearing that up
Posted: 2013-06-09 12:25:01
So from all the rumors it seems Honami will have almost perfect HW, top of its class in everything. But how about SW, has Sony learned its lessons regarding upgrades ? If Honami comes out with 4.2.2 at the end of 3Q, then we'll have the next major version of Android (KLP, 5.0 ?) probably coming out around 2 months later. My hope is that Sony is using the "vanilla" version as much as possible and adds just apps where it can be done. There will have to be unique software parts for e.g. the camera, audio etc of course.
Posted: 2013-06-09 12:26:05
I believe Honami will ship with 4.3
Don't have confirmation so take this with bags of salt
BTW where did the Xperia Z Google Edition rumor start????
[ This Message was edited by: randomuser on 2013-06-09 11:50 ]
Posted: 2013-06-09 12:34:32
Yes, but there will most likely be a newer major Android version coming around November.
Posted: 2013-06-09 12:49:23
@Ramu; you are never "wrong" you just change your info often (which is exactly like being wrong just without admitting it). At least when I'm wrong I can admit it;
I was wrong on suggesting a 4.8 screen (and that was a low XR anyway)
And I was wrong on stating that Honami won't have Xenos (what you were right all along)
But my screen specs are legit (I have complete specs but won't leak it all right away) I was right about 13MP, and I did not mention anything about Xperia Z module ending up in Honami. I said Honami is going with 13MP like Z but a better camera overall.
C'mon man you even suggested 80K for S800 on AnTuTu was legit!
Anyway, here's another screen spec for Honami;
700cd/m2 max brightness with tiniest LCD panel ever (1.5 mm bezel)
[ This Message was edited by: Ambivalent_ on 2013-06-09 11:50 ]
Posted: 2013-06-09 12:49:31
I will take that with truckloads of salt simply because not ONE thing you said has ever been proved right.
If your screen info turns right then I will definitely change my mind.
Posted: 2013-06-09 12:52:39
^ 700cd/m^2 is not impressive at all htc One 670cd/m^2 and I believe Xperia P white level is beyond 1000
1.5mm bezel is also not really ground breaking. Xperia ZL has 2.4mm bezel on each side which not all of that is display bezel.
How about black levels?
Is it IGZO or Triluminos?
Posted: 2013-06-09 13:02:21
ceasefire! ceasefire!
spread the love, not the hate
Posted: 2013-06-09 13:03:00
