General discussions : Non mobile discussion : Need HELP! DVD-R troubles...
thats the message i get...
it pops-up when i click on my D: drive via windows explorer...It has an assortment of files on there which i want to transfer off.
Posted: 2006-04-03 18:16:03
Try this
and maybe uninstall all cd/dvd buring soft ,then re-install.
Posted: 2006-04-03 18:41:20
On 2006-04-03 18:41:20, shyam335 wrote:
Try this
cheers... i dont have xp though... think its still worth a go?
Posted: 2006-04-03 18:51:37
Oh i didnt notice you were running win2k,You got all service packs?
and if u have norton installed?
and sometimes you need to install a driver for your dvd drive since its win 2k.
There are a terrible lot of lies going around the world, and the worst of it is half of them are true - Winston Churchill
We shape our buildings; thereafter they shape us - Winston Churchill
[ This Message was edited by: shyam335 on 2006-04-03 18:26 ]
Posted: 2006-04-03 19:21:17
Yeh got the latest SP. SP4 i think
And also norton AV installed
I was thinking about finding a driver and instaling it. But im afraid it would mess things up if i already have on installed and my drive is just not capable of reading that format of DVD.
Anyway of cheking whether or not i have the correct drivers installed?
Thanks for you help
Posted: 2006-04-03 19:39:29
Try disabling norton for a while,restart and see,
To see the drivers ,control panel >system>device mngr>cd/dvd ....
Posted: 2006-04-03 19:49:38
Also..try downloading a nifty little tool called Driver detective & run it...itll tell you if there are any drivers on your machine that need updating
Posted: 2006-04-03 20:07:00
got that programme
ran it
it found some drivers that needed updating, i.e video card, scanner etc etc
but nothing was mentioned about CD/DVD drive
will give that a go now
Thanks ppl
EDIT: ok tired that.. didnt work
Also clicked went through my driver list and selected the NEC 5700A drive. Clicked update driver but it said ialready have a suitable driver installed.... hmmm
Wow 2300+ posts....
[ This Message was edited by: 50Cent on 2006-04-03 20:06 ]
Posted: 2006-04-03 20:55:51
