General discussions : Non mobile discussion : using hifi as pc speakers
< Esato Forum Index > General discussions > Non mobile discussion > using hifi as pc speakers Bookmark topic
Page <  12
siamese plantpot Posts: 136
yes the problem is that there is one socket for each speaker yet the cable has wire for stereo. is there any way to set the pc to put stereo sound through one socket?
Posted: 2006-05-26 11:49:24
leeboy13 Posts: > 500
do you mean the one 3.5mm jack that links to your pc?
because a 2.5mm jack (only one) provides a two channel output (look closely at the 3.5mm jack it has two halfs and top and bottom... anyway, go into sound in your control panel and there should be a setting there for your poutput..... one speaker, two speakers, 5 speakers etc...... i if im correct i think... its in advanced i think in teh audio tab......
Posted: 2006-05-26 11:53:50
yea i do mean that, the problem im seeing is that the pc speakers i was using before have one green port at the top that led to the the speaker with volume controls etc on it and a pink one to the other. the green port is above the pink one on the back of the pc. i dont know if that tells you anything?
iv now set the sound up to surround sound though which is all good!
mike
Posted: 2006-05-26 12:00:06
teh pink is for a microphone i think mate.... the green is for your sound (speakers)
glad it seems to be working, nice one matey
Posted: 2006-05-26 12:24:26
thanks a lot leeboy =]]
and ill just pretend the comment about pink never happened
mike
Posted: 2006-05-26 12:25:28
Page <  12
